    Padrão erro a iniciar o squid
    alguem sabe o que pode ser esse erro:
    Código :
    srv-cony:/etc/init.d # ./squid start
    Starting WWW-proxy squid  (/var/cache/squid)./squid: line 54: 12151 Aborted                 $SQUID_BIN -z -F >/dev/null 2>&1
     - Could not create cache_dir !
        failed
    wrochal
    Caro,
    Execute o comando:
    squid -z
    E caso de algum erro, reporte.
    Código :
    srv-cony:/etc/init.d # squid -z
    2005/09/05 15:42:36| squid.conf line 4: acl QUERY urlpath_regex cgi-bin ?
    2005/09/05 15:42:36| aclParseRegexList: Invalid regular expression '?': Invalid preceding regular expression
    FATAL: getgrnam failed to find groupid for effective group 'squid'
    Squid Cache (Version 2.5.STABLE6): Terminated abnormally.
    CPU Usage: 0.006 seconds = 0.003 user + 0.003 sys
    Maximum Resident Size: 0 KB
    Page faults with physical i/o: 0
    Aborted
    Vai o squid.conf
    Código :
    http_port 10.1.1.2:3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    # memoria usada:
    cache_mem 32 MB
    #esvazia o cache:
    cache_swap_low 90a
    cache_swap_high 93
    maximum_object_size 6144 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 100 KB
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    cache_replacement_policy lru
    memory_replacement_policy lru
    # disco usado (5gb) :
    cache_dir ufs /var/cache/squid 5000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl rede src 192.168.0.0/255.255.255.0
    # Minhas acls
    acl porn1 dstdomain /etc/squid/blacklist/porn/domains
    acl porn2 dstdomain /etc/squid/blacklist/porn/urls
    acl violence1 dstdomain /etc/squid/blacklist/violence/domains
    acl violence2 dstdomain /etc/squid/blacklist/violence/urls
    acl hacking1 dstdomain /etc/squid/blacklist/hacking/domains
    acl hacking2 dstdomain /etc/squid/blacklist/hacking/urls
    acl extras dstdomain /etc/squid/blacklist/extras
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    http_access allow localhost
    http_access allow rede
    # Meus bloqueios
    http_access deny porn1
    http_access deny porn2
    http_access deny violence1
    http_access deny violence2
    http_access deny hacking1
    http_access deny hacking2
    http_access deny extras
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    cache_effective_user squid
    cache_effective_group squid
    httpd_accel_port 80
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    veio vc ja criou o grupo e usuario squid ??
    ja deu permição de escrita no
    /var/cache/squid e no /var/log/squid/ ??
    Já resolvi o problens.
    Código :
    no_cache deny QUERY
    era pra estar com um \?
    Código :
    no_cache deny QUERY
    fpmazzi
    opa ... ew tbm tava com o mesmo prob ... aki .... nao precisei posta valew ...
    Citação Postado originalmente por fpmazzi
    Aeeeee, alguem que en vez de postar um novo tópico pesquisou um que já havia. Isso eh muito raro por aqui.
    fpmazzi
    Valew visitante, mas axo ke o forum eh pra isso mesmo, primeiro pesquisar, dpois posta .... inclusive eu guardo todo o historico das mensagens ke recebo, pois se um dia precisar primeiro vejo la, depois aki e se nao axa nada ae eu posto ...
