hello Guys!!
Ai gente, eu estou tentando instalar o SARG no meu Servidor Debian, que por sinal ja esta rodando o SQUID, mas eu ja tentei Instalar o SARG usando apt-get e me uma mensagem de erro:
ebserver:/tmp# apt-get -f install libc6
Reading Package Lists... Done
Building Dependency Tree... Done
Sorry, libc6 is already the newest version.
You might want to run `apt-get -f install' to correct these:
Sorry, but the following packages have unmet dependencies:
libdb1-compat: Depends: libc6 (>= 2.2.5-13) but 2.2.5-11.8 is to be installed
sarg: Depends: libc6 (>= 2.3.2.ds1-21) but 2.2.5-11.8 is to be installed
Depends: libgd2-noxpm (>= 2.0.33) but it is not going to be installed or
libgd2-xpm (>= 2.0.33) but it is not installable
Depends: ttf-bitstream-vera but it is not installable
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
eu ja tentei baixar o pacote .Deb do sarg e instalar com o dpkg:
webserver:/tmp# dpkg -i sarg_2.0.5.dfsg-1_i386.deb
(Reading database ... 19486 files and directories currently installed.)
Preparing to replace sarg 2.0.5.dfsg-1 (using sarg_2.0.5.dfsg-1_i386.deb) ...
Unpacking replacement sarg ...
dpkg: dependency problems prevent configuration of sarg:
sarg depends on libc6 (>= 2.3.2.ds1-21); however:
Version of libc6 on system is 2.2.5-11.8.
sarg depends on libgd2-noxpm (>= 2.0.33) | libgd2-xpm (>= 2.0.33); however:
Package libgd2-noxpm is not installed.
Package libgd2-xpm is not installed.
sarg depends on ttf-bitstream-vera; however:
Package ttf-bitstream-vera is not installed.
dpkg: error processing sarg (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
sarg
webserver:/tmp#
ja tentei baixar os pacotes tb ai continua dando erro de dependencias!!
o q q e possivel de se fazer? por favor pessoal, manda uma luz ai!! brigadao!!!! t+
Citação
