Postado originalmente por
mistymst
seria bom especificar o host no ldapadd, acho que é o -h pára isso, faz o teste, verifique se o ldap ta rodando mesmo, poste o seu netstat
netstat
Active Internet connections
Proto Recv-Q Send-Q Local Address Foreign Address (state)
tcp4 0 0 srv-net.ssh interno-2-90.1105 ESTABLISHED
udp4 0 0 srv-net.netbios-dgm *.*
udp4 0 0 srv-net.netbios-ns *.*
udp4 0 0 localhost.domain *.*
Active UNIX domain sockets
Address Type Recv-Q Send-Q Inode Conn Refs Nextref Addr
c1a56c94 stream 0 0 0 c1a56a64 0 0
c1a56a64 stream 0 0 0 c1a56c94 0 0
c1a5a000 stream 0 0 0 c1a5a08c 0 0
c1a5a08c stream 0 0 0 c1a5a000 0 0
c1a5a118 stream 0 0 c1a50000 0 0 0 private/bsmtp
c1a5a1a4 stream 0 0 0 c1a5a230 0 0
c1a5a230 stream 0 0 0 c1a5a1a4 0 0
c1a5a2bc stream 0 0 c1a50108 0 0 0 private/ifmail
c18ce08c stream 0 0 0 c18ce118 0 0
c18ce118 stream 0 0 0 c18ce08c 0 0
c18ce1a4 stream 0 0 c1a50210 0 0 0 private/uucp
c18ce230 stream 0 0 0 c18ce2bc 0 0
c18ce2bc stream 0 0 0 c18ce230 0 0
c18ce348 stream 0 0 c1a50318 0 0 0 private/cyrus
c18ce3d4 stream 0 0 0 c18ce460 0 0
c18ce460 stream 0 0 0 c18ce3d4 0 0
c18ce4ec stream 0 0 c1a50420 0 0 0 private/lmtp
c18ce578 stream 0 0 0 c18ce604 0 0
c18ce604 stream 0 0 0 c18ce578 0 0
c18ce690 stream 0 0 c1a50528 0 0 0 private/virtual
c18ce71c stream 0 0 0 c18ce7a8 0 0
c18ce7a8 stream 0 0 0 c18ce71c 0 0
c18ce834 stream 0 0 c1a50630 0 0 0 private/local
c18ce8c0 stream 0 0 0 c18ce94c 0 0
c18ce94c stream 0 0 0 c18ce8c0 0 0
c18ce9d8 stream 0 0 c1a50738 0 0 0 private/error
c18cea64 stream 0 0 0 c18ceaf0 0 0
c18ceaf0 stream 0 0 0 c18cea64 0 0
c18ceb7c stream 0 0 c1a50840 0 0 0 public/showq
c18cec08 stream 0 0 0 c18cec94 0 0
c18cec94 stream 0 0 0 c18cec08 0 0
c18ced20 stream 0 0 c1a50948 0 0 0 private/smtp
c18cedac stream 0 0 0 c18cee38 0 0
c18cee38 stream 0 0 0 c18cedac 0 0
c18ceec4 stream 0 0 c1a50a50 0 0 0 public/flush
c1a56000 stream 0 0 0 c1a5608c 0 0
c1a5608c stream 0 0 0 c1a56000 0 0
c1a56118 stream 0 0 c1a50b58 0 0 0 private/defer
c18cdb7c stream 0 0 0 c18cdaf0 0 0
c18cdaf0 stream 0 0 0 c18cdb7c 0 0
c18cd94c stream 0 0 c1a50c60 0 0 0 private/bounce
c18cd000 stream 0 0 0 c18cd08c 0 0
c18cd08c stream 0 0 0 c18cd000 0 0
c18cd118 stream 0 0 c1a50d68 0 0 0 private/rewrite
c18cd1a4 stream 0 0 0 c18cd230 0 0
c18cd230 stream 0 0 0 c18cd1a4 0 0
c18cd2bc stream 0 0 0 c18cd348 0 0
c18cd348 stream 0 0 0 c18cd2bc 0 0
c18cd3d4 stream 0 0 0 c18cd460 0 0
c18cd460 stream 0 0 0 c18cd3d4 0 0
c18cd4ec stream 0 0 c1a4be70 0 0 0 public/cleanup
c18cd578 stream 0 0 0 c18cd604 0 0
c18cd604 stream 0 0 0 c18cd578 0 0
c18cd690 stream 0 0 0 c18cd71c 0 0
c18cd71c stream 0 0 0 c18cd690 0 0
c18cd7a8 stream 0 0 0 c18cd834 0 0
c18cd834 stream 0 0 0 c18cd7a8 0 0
c18cdc08 stream 0 0 c18d9840 0 0 0 /var/run/rpcbind.sock
c18ce000 stream 0 0 c18cc108 0 0 0 /var/run/devd.pipe
c1a56230 dgram 0 0 0 c18cde38 0 c1a569d8
c1a569d8 dgram 0 0 0 c18cde38 0 c1a56ec4
c1a568c0 dgram 0 0 0 c18cddac 0 c18cd9d8
c1a56ec4 dgram 0 0 0 c18cde38 0 c18cd8c0
c18cd8c0 dgram 0 0 0 c18cde38 0 c18cdc94
c18cd9d8 dgram 0 0 0 c18cddac 0 0
c18cdc94 dgram 0 0 0 c18cde38 0 0
c18cdd20 dgram 0 0 c18ac210 0 0 0 /var/named/var/run/log
c18cddac dgram 0 0 c18ac318 0 c1a568c0 0 /var/run/log
c18cde38 dgram 0 0 c18ac420 0 c1a56230 0 /var/run/logpriv
c18cdec4 dgram 0 0 c18ac528 0 0 0 /var/run/log
