Gente configurei o DNS daqui e ta funcionando quando chamo www.accesspower.com.br ele acessa o apache normal, da tentei criar um servidor de email e descobri que meu reverso naum ta normal quando testo ele no www.terra.com.br/postmaster da o seguinte erro
ERRO
$ host 200.223.252.243
Host 243.252.223.200.in-addr.arpa not found: 3(NXDOMAIN)
Segue abaixo meus arquivos de acordo com oque a telemar mandou preciso muito de ajuda.
named.conf
options {
directory "/var/named";
allow-transfer{
200.223.252.243;
listen-on{
200.223.252.243;
127.0.0.1;
* If there is a firewall between you and nameservers you want
* to talk to, you might need to uncomment the query-source
* directive below. Previous versions of BIND always asked
* questions using port 53, but BIND 8.1 uses an unprivileged
* port by default.
*/ version "[EF DNS SERVER]";
query-source address * port 53;
dump-file "/var/named/dump/named_dump.db";
statistics-file "/var/named/dump/named.stats";
// a shared secret for the rndc tool
// this key must be the same one that is in the
// /etc/rndc.conf file
key key_rndc{
algorithm "hmac-md5";
secret "kZpfpfxdUYkuHRKHkd5n4g==";
// a control channel for the new rndc tool
controls{
inet 127.0.0.1 allow{
localhost;
} keys{
key_rndc;
zone "." {
type hint;
file "named.ca";
zone "accesspower.com.br" {
type master;
file "accesspower.com.br.db";
zone "0.0.127.in-addr.arpa" {
type master;
file "named.local";
zone "240-247.252.223.200.IN-ADDR.ARPA" {
type master;
file "accesspower.com.br.rev";
Meu accesspower.com.br.db
accesspower.com.br. IN SOA ns1.accesspower.com.br. root.ns1.accesspower.com.br. (
2006031001 ; serial
1D ; refresh
1H ; retry
1000H ; expire
1H ; default_ttl
accesspower.com.br. IN A 200.223.252.243
accesspower.com.br. IN NS ns1.accesspower.com.br.
accesspower.com.br. IN MX 5 mx.accesspower.com.br.
www IN A 200.223.252.243
ftp IN A 200.223.252.243
mx IN A 200.223.252.243
ns1 IN A 200.223.252.243
Meu accesspower.com.br.rev
@ORIGIN 240-247.252.223.200.in-addr.arpa.
@ IN SOA www.accesspower.com.br. suporte.accesspower.com.br (
200605107u ; serial
1D ; refresh
1H ; retry
1000H ; expire
1H ; default_ttl
IN NS ns4.telemar.net.br.
IN NS ns2.telemar.net.br.
243 IN PTR HYPERLINK "http://ns1.accesspower.com.br/
"ns1.accesspower.com.br
Meu named.local
@ IN SOA localhost. root.localhost. (
2006050812 ; Serial
28800 ; Refresh
14400 ; Retry
3600000 ; Expire
86400 ) ; Minimum
IN NS localhost.
Citação
