Estou tenatndo criar um dominio no xen e esta apresentando este e
#xm create /etc/xen/vm/vm3
Using config file "/etc/xen/vm/vm3".
Error: Not an HVM capable platform, we stop creating!
Alguem tem algum ideia ???
				voce está tentando instalar um domU que necessita de HVM (hardware virtualization)? poste o arquivo de configuracao e nos diga em que máquina está instalando, e em que versão do xen, por favor
Olha, eu achei uma penca de resultados no Google sobre o seu problema. Dá uma olhada:
Error: Not an HVM capable platform, we stop creating! - Pesquisa Google
# -*- mode: python; -*-
# Python configuration setup for 'xm create'.
# This script sets the parameters used when a domain is created using 'xm create'.
# You use a separate script for each domain you want to create, or
# you can set the parameters for the domain on the xm command line.
import os, re
arch = os.uname()[4]
if re.search('64', arch):
arch_libdir = 'lib64'
else:
arch_libdir = 'lib'
# Kernel image file.
kernel = "/usr/lib/xen/boot/hvmloader"
# The domain build function. HVM domain uses 'hvm'.
builder='hvm'
# Initial memory allocation (in megabytes) for the new domain.
memory = 256
# A name for your domain. All domains must have different names.
name = 'vm5'
# the number of cpus guest platform has, default=1
#vcpus=1
# enable/disable HVM guest PAE, default=0 (disabled)
pae=1
# enable/disable HVM guest ACPI, default=0 (disabled)
acpi=1
# enable/disable HVM guest APIC, default=0 (disabled)
apic=1
# List of which CPUS this domain is allowed to use, default Xen picks
#cpus = "" # leave to Xen to pick
#cpus = "0" # all vcpus run on CPU0
#cpus = "0-3,5,^1" # run on cpus 0,2,3,5
# Optionally define mac and/or bridge for the network interfaces.
# Random MACs are assigned if not given.
#vif = [ 'type=ioemu, mac=00:16:3e:00:00:11, bridge=xenbr0' ]
# type=ioemu specify the NIC is an ioemu device not netfront
vif = [ 'mac=00:16:3e:4d:64:8d' ]
# Define the disk devices you want the domain to have access to, and
# what you want them accessible as.
# Each disk entry is of the form phy:UNAME,DEV,MODE
# where UNAME is the device, DEV is the device name the domain will see,
# and MODE is r for read-only, w for read-write.
#disk = [ 'phy:hda1,hda1,r' ]
disk = [ 'phy:/dev/hda1,hdf,w' ]
# Configure the behaviour when a domain exits. There are three 'reasons'
# for a domain to stop: poweroff, reboot, and crash. For each of these you
# may specify:
# "destroy", meaning that the domain is cleaned up as normal;
# "restart", meaning that a new domain is started in place of the old
# one;
# "preserve", meaning that no clean-up is done until the domain is
# manually destroyed (using xm destroy, for example); or
# "rename-restart", meaning that the old domain is not cleaned up, but is
# renamed and a new domain started in its place.
# The default is
# on_poweroff = 'destroy'
# on_reboot = 'restart'
# on_crash = 'restart'
# For backwards compatibility we also support the deprecated option restart
# restart = 'onreboot' means on_poweroff = 'destroy'
# on_crash = 'destroy'
# restart = 'always' means on_poweroff = 'restart'
# restart = 'never' means on_poweroff = 'destroy'
# on_reboot = 'destroy'
#on_poweroff = 'destroy'
#on_reboot = 'restart'
#on_crash = 'restart'
# New stuff
device_model = '/usr/' + arch_libdir + '/xen/bin/qemu-dm'
# Disk image for
#cdrom=
# boot on floppy (a), hard disk (c) or CD-ROM (d)
#boot='d'
# write to temporary files instead of disk image files
#snapshot=1
# enable SDL library for graphics, default = 0
sdl=0
# enable VNC library for graphics, default = 1
vnc=1
# enable spawning vncviewer(only valid when vnc=1), default = 1
vncviewer=1
# no graphics, use serial port
#nographic=0
# enable stdvga, default = 0 (use cirrus logic device model)
stdvga=0
# serial port re-direct to pty deivce, /dev/pts/n
# then xm console or minicom can connect
serial='pty'
# enable ne2000, default = 0(use pcnet)
ne2000=0
# enable audio support
#audio=1
# set the real time clock to local time [default=0 i.e. set to utc]
#localtime=1
# start in full screen
#full-screen=1
A Maquina que estou usando é um notebook P IV - 512mb Ram
host : desk-Sled
release : 2.6.16.21-0.8-xen
version : #1 SMP Mon Jul 3 18:25:39 UTC 2006
machine : i686
nr_cpus : 1
nr_nodes : 1
sockets_per_node : 1
cores_per_socket : 1
threads_per_core : 1
cpu_mhz : 2392
hw_caps : bfebfbff:00000000:00000000:00000080
total_memory : 503
free_memory : 29
max_free_memory : 288
xen_major : 3
xen_minor : 0
xen_extra : .2_09749-0.4
xen_caps : xen-3.0-x86_32
platform_params : virt_start=0xfc000000
xen_changeset : 09749
cc_compiler : gcc version 4.1.0 (SUSE Linux)
cc_compile_by : abuild
cc_compile_domain : suse.de
cc_compile_date : Mon Jul 3 19:20:34 UTC 2006
desk-Sled:/etc/xen/vm #
processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 2
model name : Intel(R) Pentium(R) 4 CPU 2.40GHz
stepping : 7
cpu MHz : 2392.324
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
flags : fpu tsc msr pae mce cx8 apic mtrr mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe
bogomips : 5984.19
Descobri que meu processador não tem suporte a vt.
Alguem sabe se existe alguma outra opção de usar xen,
colocando no arquivo de configuração parmetro builder difrente de hvm.
