- Problema com kernel !!!
Olá Galera
Preciso muito da ajuda de vocês, estou usando o slakcware 10.2 e re-compilando o kernel até este ponto normal, problema é que tenho dois hds sata que estão funcionando com Raid-1 (usando o Linux), quando começo a carregar a inicialização do Linux ocorre problema, abaixo coloquei a mensagem :
mount : mounting /dev/md0 on /mnt/ falied invalid argument
error : mount returned error code troble ahead
mount: mounting /dev/md0 on /mnt/ failed invalid argument
mount : mounting /dev/md0 on /mnt/ failed invalid argument
/boot/initrd.gz
pivot_root: pivot_root : device or resource busy
sh_202: reiserfs_read_super can not find reiserfs on (md9,0)
Observação
Fiz a imagem RAM disk, usando o seguinte comando
mkinitrd -f reiserfs -k 2.4.31 -r /dev/md0 -m sata_via -o /boot/initrd24.img
Mensagens da controladora SATA-VIA no carregamento do sistema
sata_via(00:0f.0): routed to hard irq line 11
ata1: SATA max UDMA/133 cmd 0x9000 ctl 0x9402 bmdma 0xA000 irq 11
ata2: SATA max UDMA/133 cmd 0x9800 ctl 0x9C02 bmdma 0xA008 irq 11
ata1: dev 0 cfg 49:2f00 82:746b 83:7f01 84:4023 85:7468 86:bc01 87:4023 88:40ff
ata1: dev 0 ATA, max UDMA7, 312579695 sectors: lba48
ata1: dev 0 configured for UDMA/133
ata2: dev 0 cfg 49:2f00 82:746b 83:7f01 84:4023 85:7468 86:bc01 87:4023 88:40ff
ata2: dev 0 ATA, max UDMA7, 312581808 sectors: lba48
ata2: dev 0 configured for UDMA/133
scsi0 : sata_via
scsi1 : sata_via
Vendor: ATA Model: SAMSUNG HD160JJ Rev: ZM10
Type: Direct-Access ANSI SCSI revision: 05
Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
Attached scsi disk sdb at scsi1, channel 0, id 0, lun 0
SCSI device sda: 312579695 512-byte hdwr sectors (160041 MB)
Partition check:
sda: sda1 sda2
SCSI device sdb: 312581808 512-byte hdwr sectors (160042 MB)
sdb: sdb1
md: linear personality registered as nr 1
md: raid0 personality registered as nr 2
md: raid1 personality registered as nr 3
md: raid5 personality registered as nr 4
raid5: measuring checksumming speed
8regs : 3250.000 MB/sec
32regs : 2202.400 MB/sec
pIII_sse : 5154.800 MB/sec
pII_mmx : 3196.400 MB/sec
p5_mmx : 3213.600 MB/sec
raid5: using function: pIII_sse (5154.800 MB/sec)
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: Autodetecting RAID arrays.
[events: 0000002e]
[events: 0000002e]
md: autorun ...
md: considering sdb1 ...
md: adding sdb1 ...
md: adding sda1 ...
md: created md0
md: bind<sda1,1>
md: bind<sdb1,2>
md: running: <sdb1><sda1>
md: sdb1's event counter: 0000002e
md: sda1's event counter: 0000002e
md: RAID level 1 does not need chunksize! Continuing anyway.
md0: max total readahead window set to 124k
md0: 1 data-disks, max readahead per data-disk: 124k
raid1: device sdb1 operational as mirror 1
raid1: device sda1 operational as mirror 0
raid1: raid set md0 active with 2 out of 2 mirrors
md: updating md0 RAID superblock on device
md: sdb1 [events: 0000002f]<6>(write) sdb1's sb offset: 155766144
md: sda1 [events: 0000002f]<6>(write) sda1's sb offset: 155766144
md: ... autorun DONE.
md: Ignoring md=0, already autodetected. (Use raid=noautodetect)
LVM version 1.0.8(17/11/2003)
Initializing Cryptographic API
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 8192 buckets, 64Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
FAT: bogus logical sector size 0
UMSDOS: msdos_read_super failed, mount aborted.
md: swapper(pid 1) used obsolete MD ioctl, upgrade your software to use new ictls.
reiserfs: found format "3.6" with standard journal
reiserfs: checking transaction log (device md(9,0)) ...
for (md(9,0))
md(9,0):Using r5 hash to sort names
VFS: Mounted root (reiserfs filesystem) readonly.
Freeing unused kernel memory: 120k freed
Adding Swap: 522104k swap-space (priority -1)
Linux agpgart interface v0.99 (c) Jeff Hartmann
agpgart: Maximum main memory to use for agp memory: 816M
agpgart: Unsupported Via chipset (device id: 0314), you might want to try agp_try_unsupported=1.
agpgart: no supported devices found.
scsi2 : SCSI host adapter emulation for IDE ATAPI devices
Se alguém pode me ajudar agradeço ..
Obrigado !
