8O o postfix sempre rodou certinho mais agora quando coloco uma nova conta de e-mail ele nao recebe so envia oque esta acontessendo ???
LLLLLLLLLLLLLLLLLLLLLLLLLLLOOOOOOOOOOOOOOOOOOOOGGGGGGGGGGGSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sao 3 nomes de e-mail que nao querem recebe abuse, postmaster, marketing qualquer otro usuario que eu crie ele funciona normal!! ja apagei e fix de novo mais nao adianta
ai esta o log nao sei se é o serto eu tirei de /var/log/maillog
Jan 14 09:02:19 mail postfix/smtpd[7705]: connect from unknown[192.168.2.4]Jan 14 09:02:19 mail postfix/smtpd[7705]: AEC8C5C04F: client=unknown[192.168.2.4]
Jan 14 09:02:19 mail postfix/cleanup[7707]: AEC8C5C04F: message-id=<002901c4fa28$a76ad9d0$0402a8c0@estacao4>Jan 14 09:02:19 mail postfix/smtpd[7705]: disconnect from unknown[192.168.2.4]Jan 14 09:02:19 mail postfix/nqmgr[1363]: AEC8C5C04F: from=<[email protected]>, size=1439, nrcpt=2 (queue active)Jan 14 09:02:19 mail postfix/local[7709]: AEC8C5C04F: to=<[email protected]>, orig_to=<[email protected]>, relay=local, delay=0, status=sent (mailbox)Jan 14 09:02:20 mail postfix/local[7710]: AEC8C5C04F: to=<[email protected]>, orig_to=<[email protected]>, relay=local, delay=1, status=sent (mailbox)
acho que esse ta melhor
Jan 14 09:30:31 mail imap-login: Login: postmaster [127.0.0.1]
Jan 14 09:30:31 mail last message repeated 2 times
Jan 14 09:30:43 mail postfix/smtpd[7930]: connect from mail.fire.ind.br[127.0.0.1]
Jan 14 09:30:43 mail postfix/smtpd[7930]: B7B4D5C062: client=mail.fire.ind.br[127.0.0.1], sasl_method=LOGIN, sasl_username=postmaster
Jan 14 09:30:43 mail postfix/cleanup[7932]: B7B4D5C062: message-id=<[email protected]>
Jan 14 09:30:43 mail postfix/nqmgr[1363]: B7B4D5C062: from=<[email protected]>, size=688, nrcpt=1 (queue active)
Jan 14 09:30:43 mail postfix/smtpd[7930]: disconnect from mail.fire.ind.br[127.0.0.1]
Jan 14 09:30:43 mail imap-login: Login: postmaster [127.0.0.1]
Jan 14 09:30:43 mail postfix/local[7934]: B7B4D5C062: to=<[email protected]>, orig_to=<[email protected]>, relay=local, delay=0, status=sent (mailbox)
Jan 14 09:30:44 mail imap-login: Login: postmaster [127.0.0.1]
Jan 14 09:30:55 mail postfix/smtpd[7930]: connect from mail.fire.ind.br[127.0.0.1]
Jan 14 09:30:56 mail postfix/smtpd[7930]: 07BCF5C062: client=mail.fire.ind.br[127.0.0.1], sasl_method=LOGIN, sasl_username=postmaster
Jan 14 09:30:56 mail postfix/cleanup[7932]: 07BCF5C062: message-id=<[email protected]>
Jan 14 09:30:56 mail postfix/smtpd[7930]: disconnect from mail.fire.ind.br[127.0.0.1]
Não tem absolutamente nada de errado nos logs: a única coisa que eu percebí é que a autenticação está sendo feita por sasl_auth - pode ser até que este parâmetro esteja setado de modo incorreto, depende da tua configuração e via squirrelmail - não sabia que o squirrel tinha este recurso!
Mande a saída do comando postmap -n...
Fui,
nao sei como funciona o comando postmap !!!
esse negocio ta esquesito pq ele funciona normal um usuario por exemplo "teste" ele envia e recebe normal... e se eu fize o "abuse" ,""postmaster" so envia nao recebe nada teve uma hora que recebeu depois paro tanto via outlook ou squirrel !
:wink: Aliases nao fazia nem ideia que ele fazia isso
