Estive tentando instalar o BlackBox, mas apareceu o seguinte erro:
[root@ci blackbox-0.65.0]# ./configure
loading cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... missing
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for c++... c++
checking whether the C++ compiler (c++ ) works... no
configure: error: installation or configuration problem: C++ compiler cannot create executables.
Segue abaixo o config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
configure:572: checking for a BSD compatible install
configure:625: checking whether build environment is sane
configure:682: checking whether make sets ${MAKE}
configure:721: checking for working aclocal
configure:734: checking for working autoconf
configure:747: checking for working automake
configure:760: checking for working autoheader
configure:773: checking for working makeinfo
configure:793: checking for gcc
configure:906: checking whether the C compiler (gcc ) works
configure:922: gcc -o conftest conftest.c 1>&5
configure:948: checking whether the C compiler (gcc ) is a cross-compiler
configure:953: checking whether we are using GNU C
configure:962: gcc -E conftest.c
configure:981: checking whether gcc accepts -g
configure:1017: checking for c++
configure:1049: checking whether the C++ compiler (c++ ) works
configure:1065: c++ -o conftest conftest.C 1>&5
/usr/bin/ld: cannot find -lstdc++
collect2: ld returned 1 exit status
configure: failed program was:
#line 1060 "configure"
#include "confdefs.h"
int main(){return(0);}
Será que algue sabe qual pacote está faltando?
RICARDO DE PAIVA SILVA
