Problema no squid..seguinte ele...esta configurado pra autencacao..mais nao atentica...
ele geral loga normal access.log
que pode ser,,,eu uso slackware 10
caixa de senha ele nao mostrar que pode ser
root 1322 0.0 0.8 3596 1028 ? Ss 00:07 0:00 /usr/local/squid/sbin/squid start
squid 1324 0.8 8.0 11920 10244 ? S 00:07 0:06 (squid) start
squid 1325 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
squid 1326 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
squid 1327 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
squid 1328 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
squid 1329 0.0 0.2 1820 364 ? Ss 00:07 0:00 (ncsa_auth) /usr/local/squid/etc/passwd
squid 1330 0.0 0.2 1316 268 ? Ss 00:07 0:00 (unlinkd)
root 1348 0.0 0.6 2276 788 pts/0 R+ 00:22 0:00 ps aux
http_port 3128
icp_port 0
cache_mem 100 MB
cache_swap_low 95
cache_swap_high 98
maximum_object_size 61440 KB
maximum_object_size_in_memory 4096 KB
cache_dir ufs /usr/local/squid/var/cache 900 16 256
cache_access_log /usr/local/squid/var/logs/access.log
cache_store_log /usr/local/squid/var/logs/store.log
cache_log /var/log/squid/cache.log
emulate_httpd_log on
log_fqdn on
ftp_passive on
refresh_pattern . 0 20% 4320
#Defaults:
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563
acl Safe_ports port 80 21 443 563 70 210 1025-65535
acl CONNECT method CONNECT
auth_param basic program /usr/local/squid/libexec/ncsa_auth /usr/local/squid/etc/passwd
auth_param basic children 5
auth_param basic realm Digite login e senha:
auth_param basic credentialsttl 1 hours
acl blacklist url_regex "/usr/local/squid/etc/blacklist"
acl whitelist url_regex "/usr/local/squid/etc/whitelist"
acl password proxy_auth "/usr/local/squid/etc/passwd"
acl minharede src 192.168.0.0/255.255.255.0
http_access allow manager localhost all
http_access deny manager
http_access deny !Safe_ports
http_access deny blacklist
http_access allow whitelist all
http_access allow minharede
http_access allow password
http_access deny all
icp_access allow all
miss_access allow all
cache_effective_user squid
cache_effective_group squid
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
visible_hostname proxy.ddd.com.br
cache_mgr ddd
error_directory /usr/local/squid/share/errors/Portuguese
Citação
