Pessoal,
segui este artigo de cabo a rabo http://www.vivaolinux.com.br/artigos...hp?codigo=1049
mas estou com problema no arquivo .jnl, acompanhando o meu syslog abaixo, podem perceber que o sistema tenta criá-lo mas não consegue. já tentei criar este arquivo com touch, mas não resolve não sei o que mais fazer. tb estou mandando meus confs. se alguém puder me dar uma luz fico muito grato. ogribado.
########### INICIANDO O BIND
Jan 25 18:21:51 ptbh-deb named[13567]: starting BIND 9.2.4 -u bind
Jan 25 18:21:52 ptbh-deb named[13567]: using 1 CPU
Jan 25 18:21:52 ptbh-deb named[13567]: loading configuration from '/etc/bind/named.conf'
Jan 25 18:21:52 ptbh-deb named[13567]: listening on IPv4 interface lo, 127.0.0.1#53
Jan 25 18:21:52 ptbh-deb named[13567]: listening on IPv4 interface eth0, 201.17.135.86#53
Jan 25 18:21:52 ptbh-deb named[13567]: listening on IPv4 interface eth1, 13.13.13.1#53
Jan 25 18:21:52 ptbh-deb named[13567]: zone 'ptbh.net.br' allows updates by IP address, which is insecure
Jan 25 18:21:52 ptbh-deb named[13567]: zone '13.13.in-addr-arpa' allows updates by IP address, which is insecure
Jan 25 18:21:52 ptbh-deb named[13567]: command channel listening on 127.0.0.1#953
Jan 25 18:21:52 ptbh-deb named[13567]: zone 0.in-addr.arpa/IN: loaded serial 1
Jan 25 18:21:52 ptbh-deb named[13567]: zone 127.in-addr.arpa/IN: loaded serial 1
Jan 25 18:21:52 ptbh-deb named[13567]: zone 255.in-addr.arpa/IN: loaded serial 1
Jan 25 18:21:52 ptbh-deb named[13567]: zone ptbh.net.br/IN: loaded serial 1
Jan 25 18:21:52 ptbh-deb named[13567]: zone 13.13.in-addr-arpa/IN: loaded serial 1
Jan 25 18:21:52 ptbh-deb named[13567]: zone localhost/IN: loaded serial 1
Jan 25 18:21:52 ptbh-deb named[13567]: running
######## Estação pegando IP e tentando atualizar zona.
Jan 25 18:21:56 ptbh-deb named[13567]: client 127.0.0.1#1825: updating zone 'ptbh.net.br/IN': adding an RR
Jan 25 18:21:56 ptbh-deb named[13567]: journal file /etc/bind/ptbh.db.jnl does not exist, creating it
Jan 25 18:21:56 ptbh-deb named[13567]: /etc/bind/ptbh.db.jnl: create: permission denied
Jan 25 18:21:56 ptbh-deb named[13567]: client 127.0.0.1#1825: updating zone 'ptbh.net.br/IN': error: journal open failed: un$
Jan 25 18:21:56 ptbh-deb dhcpd: Unable to add forward map from ptbh-r.ptbh.net.br to 13.13.13.14: timed out
Jan 25 18:21:56 ptbh-deb dhcpd: DHCPREQUEST for 13.13.13.14 from 00:60:67:06:5b:cd (ptbh-r) via eth1
Jan 25 18:21:56 ptbh-deb dhcpd: DHCPACK on 13.13.13.14 to 00:60:67:06:5b:cd (ptbh-r) via eth1
#############named.conf
options {directory "/var/cache/bind"; auth-nxdomain yes;};
zone "." {type hint; file "/etc/bind/db.root";};
zone "localhost" {type master;file "/etc/bind/db.local";};
zone "127.in-addr.arpa" {type master;file "/etc/bind/db.127";};
zone "0.in-addr.arpa" {type master;file "/etc/bind/db.0";};
zone "255.in-addr.arpa" {type master;file "/etc/bind/db.255";};
include "/etc/bind/named.conf.local";
controls {inet 127.0.0.1 port 953 allow { 127.0.0.1; 13.13.13.1; }; };
zone "ptbh.net.br" {type master; allow-update {127.0.0.1; 13.13.13.1; }; file "/etc/bind/ptbh.db";};
zone "13.13.in-addr-arpa" {type master; allow-update {127.0.0.1; 13.13.13.1; }; file "/etc/bind/ptbh.rev";};
############### zona local
$ORIGIN ptbh.net.br.
$TTL 604800;
@ IN SOA dns1.ptbh.net.br. adm.ptbh.net.br. (
1 ; Serial
604800 ; Refresh
864000 ; Retry
2419200 ; Expire
604800 ) ; Negative Cache TTL
@ IN NS dns1.ptbh.net.br.
@ IN MX 5 mail
@ IN A 13.13.13.1
ptbh-deb IN A 13.13.13.1
mail IN A 13.13.13.1
www IN A 13.13.13.1
ftp IN A 13.13.13.1
######### reverso
;$ORIGIN 13.13.in-addr.arpa.
$TTL 604800;
1 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
1 IN PTR adm.ptbh.net.br.
Citação
