Ola pessoal, eu estou usando o slackware 10.1 com kernel 2.6.11 e tenho uma GeForce FX 5200 de 128MB eu baixei o ultimo driver da nVidia
Acontece q apos a instalaçao recompilar o kernel (depois do building kernel) ele me retorna o seguinte erro:
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
e no log (apenas onde tinha os warnings e errors) tava o seguinte:
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:642: warning
: implicit declaration of function `pci_find_class'
: assignment makes pointer from integer without a cast
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:653: warning
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:1161: warnin
g: `pm_register' is deprecated (declared at include/linux/pm.h:106)
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:1279: warnin
g: `pm_unregister' is deprecated (declared at include/linux/pm.h:111)
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:1764: warnin
g: implicit declaration of function `remap_page_range'
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:2732: warnin
g: passing arg 1 of `pmd_offset' from incompatible pointer type
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:3324: warnin
g: `inter_module_put' is deprecated (declared at include/linux/module.h:578)
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:3474: warnin
g: assignment makes pointer from integer without a cast
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:3479: warnin
/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.c:3677: error:
`PM_SAVE_STATE' undeclared (first use in this function)
(Each undeclared identifier is reported only once
for each function it appears in.)
make[3]: *** [/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/src/nv/nv.
o] Error 1
make[2]: *** [_module_/tmp/selfgz23348/NVIDIA-Linux-x86-1.0-6106-pkg1/usr/sr
c/nv] Error 2
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make[1]: *** [module] Error 1
make: *** [module] Error 2
foi isso o q aconteceu no log
ja procurei pela net e nao encontrei nada a respeito, se alguem puder me ajudar ficaria muito grato
obrigado
  Citação
