- login ssh
login ssh
amigos editei o /etc/sshd_config para tentar só 2 vezes login, usei MaxStartups 2
o q esta errado?
login ssh
#man sshd_config
MaxStartups
Specifies the maximum number of concurrent unauthenticated con-
nections to the sshd daemon. Additional connections will be
dropped until authentication succeeds or the LoginGraceTime
expires for a connection. The default is 10.
MaxAuthTries
Specifies the maximum number of authentication attempts permitted
per connection. Once the number of failures reaches half this
value, additional failures are logged. The default is 6.
http://www.openbsd.org/cgi-bin/man.c...ry=sshd_config
login ssh
so valeu 1c3_m4n, nao tinha encontrado essa opção MaxAuthTries
obrigado
login ssh
tentei colocar sua opção, mas nao funcionou
parece o seguinte erro:
/etc/ssh/sshd_config: line 39: Bad configuration option: MaxAuthTries
/etc/ssh/sshd_config: terminating, 1 bad configuration options
estou usando o slack 10 com o OpenSSH_3.8.1p1
o que pode ser ?
