- SWL-2300 no Conectiva 10
msn: [email protected]
Entaun. eu baixei o conectiva 10 fiz varias instalacoes.. tipo basica.. e instalei os pacotes.. de desnvolvimento, fiz instalacao de desenvolviemnto, e o full tb. fiz o make inject, para adicionar ao kernel. e depois o make menuconfig, e marquei o acx100 texa.. e salvei..
ah. esta instaldo o kernel source tb.. tudo oks.. mas na hora de dar um make na pasta acx100_0.2.0_pre37 da estes erro na complilacao, tenho que istalar algum pacote especifico para compilar o driver. ???
Pois o tuturial peguei no seguinte endereco.
[size=18px]http://bazar2.conectiva.com.br/pipermail/linux-br/2004-November/026540.html[/size]
[root@mould acx100-0.2.0pre8_plus_fixes_37]# make
make -C src
make[1]: Entering directory `/acx100-0.2.0pre8_plus_fixes_37/src'
gcc -Wall -Wstrict-prototypes -Wno-trigraphs -O -fno-strict-aliasing -fno-common -fomit-frame-pointer -pipe -mpreferred-stack-boundary=4 -march=i586 -DACX_DEBUG=1 -DACX_IO_WIDTH=32 -DMODVERSIONS -include /lib/modules/2.6.5-63077cl/build/include/linux/modversions.h -D__KERNEL__ -DMODULE -DWLAN_HOSTIF=WLAN_PCI -I/lib/modules/2.6.5-63077cl/build/include -I../include -c -o acx100.o acx100.c
<command line>:138133945:49664: /lib/modules/2.6.5-63077cl/build/include/linux/modversions.h: Arquivo ou diretório não encontrado
In file included from /lib/modules/2.6.5-63077cl/build/include/linux/spinlock.h:12,
from /lib/modules/2.6.5-63077cl/build/include/linux/capability.h:45,
from /lib/modules/2.6.5-63077cl/build/include/linux/sched.h:7,
from /lib/modules/2.6.5-63077cl/build/include/linux/module.h:10,
from acx100.c:70:
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:21:29: asm/thread_info.h: Arquivo ou diretório não encontrado
from acx100.c:70:
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `set_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:32: warning: implicit declaration of function `current_thread_info'
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:32: error: invalid type argument of `->'
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `clear_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:37: error: invalid type argument of `->'
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `test_and_set_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:42: error: invalid type argument of `->'
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `test_and_clear_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:47: error: invalid type argument of `->'
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `test_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:52: error: invalid type argument of `->'
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: At top level:
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:55: warning: `struct thread_info' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:55: warning: its scope is only this definition or declaration, which is probably not what you want
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `set_ti_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:57: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:60: warning: `struct thread_info' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `clear_ti_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:62: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:65: warning: `struct thread_info' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `test_and_set_ti_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:67: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:70: warning: `struct thread_info' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `test_and_clear_ti_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:72: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:75: warning: `struct thread_info' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `test_ti_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:77: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `set_need_resched':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:82: error: `TIF_NEED_RESCHED' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:82: error: (Each undeclared identifier is reported only once
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:82: error: for each function it appears in.)
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h: In function `clear_need_resched':
/lib/modules/2.6.5-63077cl/build/include/linux/thread_info.h:87: error: `TIF_NEED_RESCHED' undeclared (first use in this function)
In file included from /lib/modules/2.6.5-63077cl/build/include/linux/timex.h:186,
from /lib/modules/2.6.5-63077cl/build/include/linux/sched.h:11,
from acx100.c:70:
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:30:23: asm/div64.h: Arquivo ou diretório não encontrado
from acx100.c:70:
/lib/modules/2.6.5-63077cl/build/include/linux/time.h: In function `timespec_to_jiffies':
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:197: error: `u64' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:201: error: parse error before "sec"
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:201: error: parse error before ')' token
/lib/modules/2.6.5-63077cl/build/include/linux/time.h: In function `jiffies_to_timespec':
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:214: error: `u64' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:214: error: parse error before "nsec"
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:215: error: parse error before "result"
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:215: warning: implicit declaration of function `do_div'
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:215: error: `result' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/time.h: In function `timeval_to_jiffies':
/lib/modules/2.6.5-63077cl/build/include/linux/time.h:236: error: `u64' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:596:25: asm/current.h: Arquivo ou diretório não encontrado
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: At top level:
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:619: error: parse error before "sigset_t"
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:619: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:621: error: parse error before "sigset_t"
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:622: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `dequeue_signal_lock':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:626: error: `tsk' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:627: error: `mask' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:627: error: `info' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:634: error: parse error before "sigset_t"
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:634: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:637: warning: `struct siginfo' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:638: warning: `struct siginfo' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:639: warning: `struct siginfo' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:640: warning: `struct siginfo' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:641: warning: `struct siginfo' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:642: warning: `struct siginfo' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:643: warning: `struct siginfo' declared inside parameter list
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:658: warning: type defaults to `int' in declaration of `stack_t'
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:658: error: parse error before '*' token
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:658: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `on_sig_stack':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:669: error: `current' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `sas_ss_flags':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:674: error: `current' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:675: error: `SS_DISABLE' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:675: error: `SS_ONSTACK' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `mmdrop':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:702: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:719: error: `exit_signal' redeclared as different kind of symbol
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:393: error: previous declaration of `exit_signal'
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `thread_group_empty':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:780: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `task_lock':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:797: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `task_unlock':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:802: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `get_task_mm':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:816: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `set_tsk_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:830: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `clear_tsk_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:835: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `test_and_set_tsk_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:840: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `test_and_clear_tsk_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:845: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `test_tsk_thread_flag':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:850: error: dereferencing pointer to incomplete type
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `set_tsk_need_resched':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:855: error: `TIF_NEED_RESCHED' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `clear_tsk_need_resched':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:860: error: `TIF_NEED_RESCHED' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `signal_pending':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:865: error: `TIF_SIGPENDING' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h: In function `need_resched':
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:870: error: `TIF_NEED_RESCHED' undeclared (first use in this function)
In file included from /lib/modules/2.6.5-63077cl/build/include/linux/fs.h:14,
from /lib/modules/2.6.5-63077cl/build/include/linux/mm.h:14,
from /lib/modules/2.6.5-63077cl/build/include/linux/skbuff.h:26,
from acx100_conv.c:58:
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h: At top level:
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:26: error: parse error before "old_encode_dev"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:27: warning: return type defaults to `int'
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:31: error: parse error before "val"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:32: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h: In function `old_decode_dev':
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:33: error: `val' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:41: error: parse error before "new_encode_dev"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:42: warning: return type defaults to `int'
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:48: error: parse error before "dev"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:49: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h: In function `new_decode_dev':
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:50: error: `dev' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:60: error: parse error before "huge_encode_dev"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:61: warning: return type defaults to `int'
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:65: error: parse error before "dev"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:66: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h: In function `huge_decode_dev':
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:67: error: `dev' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:75: error: parse error before "sysv_encode_dev"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:76: warning: return type defaults to `int'
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:80: error: parse error before "dev"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:81: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h: In function `sysv_major':
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:82: error: `dev' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:85: error: parse error before "dev"
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:86: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h: In function `sysv_minor':
/lib/modules/2.6.5-63077cl/build/include/linux/kdev_t.h:87: error: `dev' undeclared (first use in this function)
In file included from /lib/modules/2.6.5-63077cl/build/include/linux/dcache.h:10,
from /lib/modules/2.6.5-63077cl/build/include/linux/fs.h:17,
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h: At top level:
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:71: error: parse error before "cpumask_t"
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:71: warning: no semicolon at end of struct or union
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:101: error: parse error before "rcu_data"
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:101: warning: type defaults to `int' in declaration of `DECLARE_PER_CPU'
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:101: warning: function declaration isn't a prototype
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:101: warning: data definition has no type or storage class
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h: In function `rcu_pending':
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:114: warning: implicit declaration of function `per_cpu'
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:114: error: `rcu_data' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:114: error: request for member `curlist' in something not a structure or union
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:115: error: request for member `batch' in something not a structure or union
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:115: error: invalid use of undefined type `struct rcu_ctrlblk'
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:116: error: request for member `curlist' in something not a structure or union
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:117: error: request for member `nxtlist' in something not a structure or union
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:118: warning: implicit declaration of function `cpu_isset'
/lib/modules/2.6.5-63077cl/build/include/linux/rcupdate.h:118: error: invalid use of undefined type `struct rcu_ctrlblk
acx100_helper.c: At top level:
acx100_helper.c:1717: error: parse error before '*' token
acx100_helper.c:1718: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_init_max_tim_template':
acx100_helper.c:1723: error: `priv' undeclared (first use in this function)
acx100_helper.c:1748: error: parse error before '*' token
acx100_helper.c:1749: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_init_max_probe_response_template':
acx100_helper.c:1755: error: `priv' undeclared (first use in this function)
acx100_helper.c:1780: error: parse error before '*' token
acx100_helper.c:1781: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_init_max_probe_request_template':
acx100_helper.c:1788: error: `priv' undeclared (first use in this function)
acx100_helper.c:1815: error: parse error before '*' token
acx100_helper.c:1816: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_set_tim_template':
acx100_helper.c:1824: error: `priv' undeclared (first use in this function)
acx100_helper.c:1860: error: parse error before '*' token
acx100_helper.c:1862: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_set_generic_beacon_probe_response_frame':
acx100_helper.c:1869: error: `bcn' undeclared (first use in this function)
acx100_helper.c:1871: error: `priv' undeclared (first use in this function)
acx100_helper.c:1956: error: parse error before '*' token
acx100_helper.c:1957: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_set_beacon_template':
acx100_helper.c:1964: error: `priv' undeclared (first use in this function)
acx100_helper.c:2004: error: parse error before '*' token
acx100_helper.c:2005: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx100_init_packet_templates':
acx100_helper.c:2020: error: `priv' undeclared (first use in this function)
acx100_helper.c:2042: error: dereferencing pointer to incomplete type
acx100_helper.c:2052: error: dereferencing pointer to incomplete type
acx100_helper.c:2073: error: parse error before '*' token
acx100_helper.c:2074: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_init_packet_templates':
acx100_helper.c:2084: error: `priv' undeclared (first use in this function)
acx100_helper.c:2123: error: parse error before '*' token
acx100_helper.c:2124: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx100_set_tx_level':
acx100_helper.c:2159: error: `priv' undeclared (first use in this function)
acx100_helper.c:2171: error: `level_dbm' undeclared (first use in this function)
acx100_helper.c:2177: error: parse error before '*' token
acx100_helper.c:2178: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_set_tx_level':
acx100_helper.c:2187: error: `level_dbm' undeclared (first use in this function)
acx100_helper.c:2190: error: `priv' undeclared (first use in this function)
acx100_helper.c:2208: error: parse error before '*' token
acx100_helper.c:2208: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_get_tx_level':
acx100_helper.c:2213: error: `priv' undeclared (first use in this function)
acx100_helper.c:2219: error: parse error before '*' token
acx100_helper.c:2220: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_get_feature_config':
acx100_helper.c:2221: error: `config' undeclared (first use in this function)
acx100_helper.c:2223: error: `priv' undeclared (first use in this function)
acx100_helper.c:2240: error: parse error before '*' token
acx100_helper.c:2241: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_recalib_radio':
acx100_helper.c:2248: error: `priv' undeclared (first use in this function)
acx100_helper.c:2251: error: parse error before '*' token
acx100_helper.c:2252: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx100_recalib_radio':
acx100_helper.c:2255: error: `priv' undeclared (first use in this function)
acx100_helper.c:2261: error: parse error before '*' token
acx100_helper.c:2262: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_set_feature_config':
acx100_helper.c:2263: error: `priv' undeclared (first use in this function)
acx100_helper.c:2267: error: `config' undeclared (first use in this function)
acx100_helper.c:2281: error: parse error before '*' token
acx100_helper.c:2282: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_set_low_power_packets':
acx100_helper.c:2285: error: `priv' undeclared (first use in this function)
acx100_helper.c:2290: error: `enable' undeclared (first use in this function)
acx100_helper.c:2305: error: parse error before '*' token
acx100_helper.c:2306: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_set_ex_low_power_packets':
acx100_helper.c:2309: error: `priv' undeclared (first use in this function)
acx100_helper.c:2314: error: `enable' undeclared (first use in this function)
acx100_helper.c:2332: error: parse error before '*' token
acx100_helper.c:2333: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx100_scan_chan_p':
acx100_helper.c:2335: error: `priv' undeclared (first use in this function)
acx100_helper.c:2337: error: `s' undeclared (first use in this function)
acx100_helper.c:2344: error: parse error before '*' token
acx100_helper.c:2345: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_scan_chan_p':
acx100_helper.c:2347: error: `priv' undeclared (first use in this function)
acx100_helper.c:2350: error: `s' undeclared (first use in this function)
acx100_helper.c:2375: error: parse error before '*' token
acx100_helper.c:2376: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx100_scan_chan':
acx100_helper.c:2382: error: `priv' undeclared (first use in this function)
acx100_helper.c:2408: error: parse error before '*' token
acx100_helper.c:2408: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_scan_chan':
acx100_helper.c:2416: error: `priv' undeclared (first use in this function)
acx100_helper.c:2436: error: parse error before '*' token
acx100_helper.c:2437: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_update_card_settings':
acx100_helper.c:2465: error: `init' undeclared (first use in this function)
acx100_helper.c:2465: error: `priv' undeclared (first use in this function)
acx100_helper.c:2470: error: `get_all' undeclared (first use in this function)
acx100_helper.c:2472: error: `set_all' undeclared (first use in this function)
acx100_helper.c:2856:2: warning: #warning Is this used anymore?
acx100_helper.c:2925: error: parse error before '*' token
acx100_helper.c:2926: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_initialize_rx_config':
acx100_helper.c:2927: error: `setting' undeclared (first use in this function)
acx100_helper.c:2929: error: `priv' undeclared (first use in this function)
acx100_helper.c:2994: error: parse error before '*' token
acx100_helper.c:2995: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_set_defaults':
acx100_helper.c:3001: error: `priv' undeclared (first use in this function)
acx100_helper.c:3184: error: parse error before '*' token
acx100_helper.c:3185: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_set_probe_response_template':
acx100_helper.c:3194: error: `priv' undeclared (first use in this function)
acx100_helper.c:3389: error: parse error before '*' token
acx100_helper.c:3390: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_join_bssid':
acx100_helper.c:3401: error: `priv' undeclared (first use in this function)
acx100_helper.c: In function `acx_init_mac':
acx100_helper.c:3491: error: `priv' undeclared (first use in this function)
acx100_helper.c:3491: error: parse error before ')' token
acx100_helper.c:3591: error: parse error before '*' token
acx100_helper.c:3592: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_start':
acx100_helper.c:3598: error: `priv' undeclared (first use in this function)
acx100_helper.c:3598: warning: left-hand operand of comma expression has no effect
acx100_helper.c:3653: error: parse error before '*' token
acx100_helper.c:3654: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_set_timer':
acx100_helper.c:3661: error: `timeout' undeclared (first use in this function)
acx100_helper.c:3662: error: `priv' undeclared (first use in this function)
acx100_helper.c:3696: error: parse error before '*' token
acx100_helper.c:3697: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_update_capabilities':
acx100_helper.c:3698: error: `priv' undeclared (first use in this function)
acx100_helper.c:3754: error: parse error before '*' token
acx100_helper.c:3756: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_read_eeprom_offset':
acx100_helper.c:3763: error: `priv' undeclared (first use in this function)
acx100_helper.c:3764: error: `addr' undeclared (first use in this function)
acx100_helper.c:3779: error: `charbuf' undeclared (first use in this function)
acx100_helper.c:3779: warning: implicit declaration of function `readb'
acx100_helper.c:3792: error: parse error before '*' token
acx100_helper.c:3793: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_read_eeprom_area':
acx100_helper.c:3799: error: `priv' undeclared (first use in this function)
acx100_helper.c:3805: error: parse error before '*' token
acx100_helper.c:3806: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_write_eeprom_offset':
acx100_helper.c:3824: error: `priv' undeclared (first use in this function)
acx100_helper.c:3828: error: `len' undeclared (first use in this function)
acx100_helper.c:3831: error: `addr' undeclared (first use in this function)
acx100_helper.c:3832: error: `charbuf' undeclared (first use in this function)
acx100_helper.c:3889: error: parse error before '*' token
acx100_helper.c:3890: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_read_phy_reg':
acx100_helper.c:3901: error: `reg' undeclared (first use in this function)
acx100_helper.c:3901: error: `priv' undeclared (first use in this function)
acx100_helper.c:3912: error: `charbuf' undeclared (first use in this function)
acx100_helper.c:3943: error: parse error before '*' token
acx100_helper.c:3944: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx_write_phy_reg':
acx100_helper.c:3948: error: `reg' undeclared (first use in this function)
acx100_helper.c:3948: error: `priv' undeclared (first use in this function)
acx100_helper.c:3956: error: `value' undeclared (first use in this function)
acx100_helper.c:3976: error: parse error before '*' token
acx100_helper.c:3977: warning: function declaration isn't a prototype
acx100_helper.c: In function `acx111_read_configoption':
acx100_helper.c:3985: error: `priv' undeclared (first use in this function)
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:442: error: storage size of `rlim' isn't known
/lib/modules/2.6.5-63077cl/build/include/linux/sched.h:463: error: storage size of `pending' isn't known
/lib/modules/2.6.5-63077cl/build/include/linux/device.h:381: error: storage size of `dev' isn't known
/usr/include/asm/hw_irq.h:27: error: storage size of `irq_vector' isn't known
make[1]: ** [acx100_helper.o] Erro 1
make[1]: Leaving directory `/acx100-0.2.0pre8_plus_fixes_37/src'
make: ** [driver] Erro 2
