Postado originalmente por
edineudo
Se eu entendi bem a duvida esta configuração no named.conf podera resolver.
Edita o arquivo
/etc/named.conf e insere as seguintes linhas em destaque.
Código :
options {
directory "/var/named";
* If there is a firewall between you and nameservers you want
* to talk to, you might need to uncomment the query-source
* directive below. Previous versions of BIND always asked
* questions using port 53, but BIND 8.1 uses an unprivileged
* port by default.
// query-source address * port 53;
forward first;
forwarders { 10.1.1.1;
