ok
ok
Ok ,, valeu ,,, acho q naum vou precisar por enquanto....
Postado originalmente por Benatto
Aproveitando a deixa do squid,,,, naum sei se jah postaram aqui no forum sobre isso mas tah aparecendo umas linhas no meu cache.log q naum consegui descobrir onde tah o erro,,, instalei o squid em dois servidores estaum basicamente identicos , e apenas em um server dah esse erro ,,,,
2005/04/22 04:09:02| sslReadServer: FD 83: read failure: (104) Connection reset by peer
2005/04/22 04:09:03| sslReadServer: FD 113: read failure: (104) Connection reset by peer
2005/04/22 04:09:04| sslReadServer: FD 61: read failure: (104) Connection reset by peer
2005/04/22 04:09:06| sslReadServer: FD 59: read failure: (104) Connection reset by peer
2005/04/22 04:09:08| sslReadServer: FD 56: read failure: (104) Connection reset by peer
2005/04/22 04:09:30| sslReadServer: FD 62: read failure: (104) Connection reset by peer
2005/04/22 04:09:51| sslReadServer: FD 62: read failure: (104) Connection reset by peer
2005/04/22 04:09:56| sslReadServer: FD 38: read failure: (104) Connection reset by peer
2005/04/22 04:09:57| sslReadServer: FD 55: read failure: (104) Connection reset by peer
2005/04/22 04:10:00| sslReadServer: FD 52: read failure: (104) Connection reset by peer
2005/04/22 04:10:01| sslReadServer: FD 64: read failure: (104) Connection reset by peer
2005/04/22 04:10:04| sslReadServer: FD 40: read failure: (104) Connection reset by peer
2005/04/22 04:10:04| sslReadServer: FD 73: read failure: (104) Connection reset by peer
2005/04/22 04:10:07| sslReadServer: FD 56: read failure: (104) Connection reset by peer
2005/04/22 04:10:10| sslReadServer: FD 63: read failure: (104) Connection reset by peer
2005/04/22 04:10:11| sslReadServer: FD 69: read failure: (104) Connection reset by peer
2005/04/22 04:10:14| sslReadServer: FD 31: read failure: (104) Connection reset by peer
2005/04/22 04:10:14| sslReadServer: FD 63: read failure: (104) Connection reset by peer
E tem horas que o trafego tah baxinho e o navegador demora pra encontra o site , to achando que eh por esse erro !! alguem pode me dah uma ajuda....
fala ai pilantrox
posta ai seu squid.conf
Ai Benatto....... tah na mão,,,,,desculpa ai a demora ,,,mas eu estava com uns problemas fds.Postado originalmente por Benatto
http_port 192.168.15.1:3128
#esvazia o cache:
cache_swap_low 90
cache_swap_high 93
hierarchy_stoplist cgi-bin ?
no_cache deny QUERY
# memoria usada:
cache_mem 32 MB
maximum_object_size 6144 KB
minimum_object_size 0 KB
maximum_object_size_in_memory 32 KB
ipcache_size 1024
ipcache_low 90
ipcache_high 93
cache_replacement_policy lru
memory_replacement_policy lru
cache_dir ufs /var/spool/squid 7000 16 256
cache_log /var/log/squid/cache.log
cache_store_log /var/log/squid/store.log
auth_param basic children 5
auth_param basic realm Squid proxy-caching web server
auth_param basic credentialsttl 2 hours
refresh_pattern . 0 20% 4320
acl all src 0.0.0.0/0.0.0.0
acl rede src 192.168.0.0/255.255.255.0
acl rede1 src 10.10.10.0/255.255.255.0
acl rede2 src 20.20.20.0/255.255.255.0
acl rede3 src 30.30.30.0/255.255.255.0
acl rede4 src 90.90.90.0/255.255.255.0
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl CONNECT method CONNECT
http_access allow localhost
http_access allow rede
http_access allow rede1
http_access allow rede2
http_access allow rede3
http_access allow rede4
http_access deny manager
http_access deny !Safe_ports
http_access deny all
http_reply_access allow all
icp_access allow all
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
cache_effective_user squid
cache_effective_group squid
ele tah lento pra resolver as solicitacoes....
Fala ae pessoal!
Achei a fonte do meu problema. Estava no arquivo ifcfg-eth0 referente a placa que comunicava com o Speedy. NETMASK não era 255.255.255.0 e sim 255.255.255.194 ops:
Valeu pela ajuda pessoal!
Falou!
Gaiotto
