- Problemas com hearbeat
Ola a todos, eu não estou conseguindo fazer o servidor secundario carregar o datadisk o meu log esta aki mas testa com erro alguem poderia me ajudar.
heartbeat: 2005/04/28_11:07:25 info: **************************
heartbeat: 2005/04/28_11:07:25 info: Configuration validated. Starting heartbeat 1.0.3
heartbeat: 2005/04/28_11:07:25 info: heartbeat: version 1.0.3
heartbeat: 2005/04/28_11:07:25 info: Heartbeat generation: 18
heartbeat: 2005/04/28_11:07:25 info: UDP Broadcast heartbeat started on port 694 (694) interface eth0
heartbeat: 2005/04/28_11:07:25 info: pid 3555 locked in memory.
heartbeat: 2005/04/28_11:07:25 info: pid 3556 locked in memory.
heartbeat: 2005/04/28_11:07:25 info: pid 3557 locked in memory.
heartbeat: 2005/04/28_11:07:25 info: pid 3559 locked in memory.
heartbeat: 2005/04/28_11:07:25 info: Local status now set to: 'up'
heartbeat: 2005/04/28_11:07:25 info: pid 3551 locked in memory.
heartbeat: 2005/04/28_11:07:26 info: pid 3558 locked in memory.
heartbeat: 2005/04/28_11:07:26 info: Link cpd009.agrovale:eth0 up.
heartbeat: 2005/04/28_11:07:26 info: Local status now set to: 'active'
heartbeat: 2005/04/28_11:07:26 info: Link cpd008.agrovale:eth0 up.
heartbeat: 2005/04/28_11:07:26 info: Status update for node cpd008.agrovale: status active
heartbeat: 2005/04/28_11:07:26 info: Running /etc/ha.d/rc.d/status status
heartbeat: 2005/04/28_11:07:26 info: No local resources [/usr/lib/heartbeat/ResourceManager listkeys cpd009.agrovale]
heartbeat: 2005/04/28_11:07:26 info: Resource acquisition completed.
heartbeat: 2005/04/28_11:11:07 WARN: node cpd008.agrovale: is dead
heartbeat: 2005/04/28_11:11:07 WARN: No STONITH device configured.
heartbeat: 2005/04/28_11:11:07 WARN: Shared disks are not protected.
heartbeat: 2005/04/28_11:11:07 info: Resources being acquired from cpd008.agrovale.
heartbeat: 2005/04/28_11:11:07 info: Running /etc/ha.d/rc.d/status status
heartbeat: 2005/04/28_11:11:07 info: Taking over resource group IPaddr::192.168.1.235
heartbeat: 2005/04/28_11:11:07 info: No local resources [/usr/lib/heartbeat/ResourceManager listkeys cpd009.agrovale]
heartbeat: 2005/04/28_11:11:07 info: Resource acquisition completed.
heartbeat: 2005/04/28_11:11:07 info: Acquiring resource group: cpd008.agrovale IPaddr::192.168.1.235 datadisk smb
heartbeat: 2005/04/28_11:11:07 info: Running /etc/ha.d/resource.d/IPaddr 192.168.1.235 start
heartbeat: 2005/04/28_11:11:08 info: /sbin/ifconfig eth0:0 192.168.1.235 netmask 255.255.255.0 broadcast 192.168.1.255
heartbeat: 2005/04/28_11:11:08 info: Sending Gratuitous Arp for 192.168.1.235 on eth0:0 [eth0]
heartbeat: 2005/04/28_11:11:08 info: Running /etc/ha.d/resource.d/datadisk start
heartbeat: 2005/04/28_11:11:08 /usr/lib/heartbeat/send_arp eth0 192.168.1.235 00112F6D9CE2 192.168.1.235 ffffffffffff
heartbeat: 2005/04/28_11:11:08 warning: Return code 255 from /etc/ha.d/resource.d/datadisk
heartbeat: 2005/04/28_11:11:08 info: Running /etc/init.d/smb start
heartbeat: 2005/04/28_11:11:08 info: mach_down takeover complete for node cpd008.agrovale.
heartbeat: 2005/04/28_11:11:08 info: Link cpd008.agrovale:eth0 dead.
heartbeat: 2005/04/28_11:11:10 /usr/lib/heartbeat/send_arp eth0 192.168.1.235 00112F6D9CE2 192.168.1.235 ffffffffffff
heartbeat: 2005/04/28_11:11:12 /usr/lib/heartbeat/send_arp eth0 192.168.1.235 00112F6D9CE2 192.168.1.235 ffffffffffff
heartbeat: 2005/04/28_11:11:14 /usr/lib/heartbeat/send_arp eth0 192.168.1.235 00112F6D9CE2 192.168.1.235 ffffffffffff
heartbeat: 2005/04/28_11:11:16 /usr/lib/heartbeat/send_arp eth0 192.168.1.235 00112F6D9CE2 192.168.1.235 ffffffffffff
