ae galera estou tentando instalar o ndiswrapper no cl10 e esta dando esse erro ai alguem sabe o que pode ser????
jah instalei o kernel-source jah fiz de tudo mais nda da certo
[root@home ndiswrapper-1.1]# make install
make -C driver install
make[1]: Entering directory `/ndiswrapper-1.1/driver'
Can't find kernel sources in /lib/modules/2.6.5-63077cl/build;
give the path to kernel sources with KSRC=<path> argument to make
make[1]: ** [prereq_check] Erro 1
make[1]: Leaving directory `/ndiswrapper-1.1/driver'
make: ** [install] Erro 2
