- Suse 9.3 + Ldap + Samba
Estou tentando configurar Suse 9.3 + LDAP e quando vou dar um:
smbldap-populate me aparece o seguinte:
linux:~ # smbldap-populate
Using workgroup name from sambaUnixIdPooldn (smbldap.conf): sambaDomainName=lteste
Using builtin directory structure
entry dc=lteste,dc=intranet already exist.
adding new entry: ou=Usuarios,dc=lteste,dc=intranet
adding new entry: ou=Grupos,dc=lteste,dc=intranet
adding new entry: ou=Computadores,dc=lteste,dc=intranet
adding new entry: ou=Idmap,dc=lteste,dc=intranet
adding new entry: sambaDomainName=lteste,dc=lteste,dc=intranet
adding new entry: uid=Administrator,ou=Usuarios,dc=lteste,dc=intranet
adding new entry: uid=nobody,ou=Usuarios,dc=lteste,dc=intranet
adding new entry: cn=Domain Admins,ou=Grupos,dc=lteste,dc=intranet
failed to add entry: no structural object class provided at /usr/local/sbin/smbldap-populate line 460, <GEN1> line 10.
adding new entry: cn=Domain Users,ou=Grupos,dc=lteste,dc=intranet
failed to add entry: no structural object class provided at /usr/local/sbin/smbldap-populate line 460, <GEN1> line 11.
adding new entry: cn=Domain Guests,ou=Grupos,dc=lteste,dc=intranet
failed to add entry: no structural object class provided at /usr/local/sbin/smbldap-populate line 460, <GEN1> line 12.
adding new entry: cn=Domain Computers,ou=Grupos,dc=lteste,dc=intranet
failed to add entry: no structural object class provided at /usr/local/sbin/smbldap-populate line 460, <GEN1> line 13.
adding new entry: cn=Administrators,ou=Grupos,dc=lteste,dc=intranet
failed to add entry: no structural object class provided at /usr/local/sbin/smbldap-populate line 460, <GEN1> line 19.
adding new entry: cn=Print Operators,ou=Grupos,dc=lteste,dc=intranet
failed to add entry: no structural object class provided at /usr/local/sbin/smbldap-populate line 460, <GEN1> line 20.
adding new entry: cn=Backup Operators,ou=Grupos,dc=lteste,dc=intranet
failed to add entry: no structural object class provided at /usr/local/sbin/smbldap-populate line 460, <GEN1> line 21.
adding new entry: cn=Replicators,ou=Grupos,dc=lteste,dc=intranet
O que fazer?
Ola amigo,
Tive o mesmo problema configurando o meu Samba com LDAP
obteve alguma resposta ?
um grande abraço
Até agora não obtive nehuma resposta e não achei nada também mas coloquei a opção schemacheck no /etc/openldap/slapd.conf como off e foi sem problemas mas me acorreu outro problema agora. Nenhuma estação Windows enxerga o dominio.
vc. usou aquele manual SQUID + LDAP + SAMBA ?
Eu procurei o Autor e ele ainda nao me respondeu se é algum erro no proprio manual ou se ele ja passou por isso
Oi amigao,
Olha só esse erro sumiu do meu hoje.
Eu refiz todo o processo de configurar o LDAP
Eu resiz todo o processo de configurar o Samba
Ai funcionou o meu problema era o sufixo que nao tinha colocado só estava Pool, ai usei dc=pool,dc=intranet
Se isto puder lhe ajudar
Tem uns tutoriais legais em http://www.ldap.org.br
Um grande abraço
em que parte só estava Pool?
Ja refiz o Samba+LDAP no Suse 9.3 umas 6 vezes e o problema é o mesmo. No Conectiva 10, demorei 30 minutos pra montar tudo e funcionar mas tenho que fazer funcionar no suse.
os arquivos que tinham somente dc=pool e alterei para dc=pool,dc=intranet
slapd.conf
ldap.conf
smb.conf
o que esta acontecendo é que ele nao esta gerando os objetos... ou seja num esta mesclando ldap com o samba
no tutorial que peguei funcionou belezinha...
Blz ?
Eu sei que nao manjo muito de linux mas no que eu puder ajudar...
Se você puder me passar o tutorial que você usou, ficaria agradecido. Vou ficar louco daqui a poko.. rs
guardian_metal arroba yahoo.com.br
Forum gente.. no Forum...
Aew,
Posta o link do tutorial que tu usou no Forum.
Assim todos tem acesso a ele.
Flws,
oi amigos bom dia !
Eu peguei o tutorial em http://www.ldap.org.br, alias tem alguns outros tbm. muito bons
um grande abraço a todos
