Alô pessoal
Estou tendo problemas com o meu dns, já tentei de tudo e sempre que executo o comando service named restart recebo a serguinte mensagem:
Parando o named: rndc: connect failed: connection refused
[FALHOU]
Iniciando named: [ OK ]
Não consegui achar erros nos arquivos de configuração, mas estou mandando-os junto com os logs do sistema.
Estou mandando os logs do sistema e os meus arquivos de configuração, se alguém poder me dar uma ajuda sou grato.
PS: uso Fedora 2
#--> /var/log/messages
[root@secinfo1 named]# tail /var/log/messages
Jul 3 14:39:11 secinfo1 named: desligar named failed
Jul 3 17:39:13 secinfo1 named[4955]: starting BIND 9.2.3 -u named -t /var/named/chroot
Jul 3 17:39:13 secinfo1 named[4955]: using 1 CPU
Jul 3 17:39:13 secinfo1 named[4955]: loading configuration from '/etc/named.conf'
Jul 3 17:39:13 secinfo1 named[4955]: /etc/named.conf:6: change directory to '/var/named' failed: permission denied
Jul 3 17:39:13 secinfo1 named[4955]: /etc/named.conf:6: parsing failed
Jul 3 17:39:13 secinfo1 named[4955]: loading configuration: permission denied
Jul 3 17:39:13 secinfo1 named[4955]: exiting (due to fatal error)
Jul 3 14:39:13 secinfo1 named: início de named succeeded
#--> /etc/named.conf
#--> /var/named/chroot/etc/named.conf
[root@secinfo1 named]# cat /etc/named.conf
//etc/named.conf
options {
directory "/var/named";
query-source address * port 53;
forwarders { 200.215.1.35; 200.180.128.69; };
forward only;
// a caching only nameserver config
controls {
inet 127.0.0.1 allow { localhost; } keys { rndckey; };
zone "." IN {
type hint;
file "named.ca";
zone "localhost" IN {
type master;
file "localhost.zone";
allow-update { none; };
zone "0.0.127.in-addr.arpa" IN {
type master;
file "named.local";
zone "rede.net" IN {
type master;
file "rede.net.hosts";
// allow-update { none; };
zone "10.168.192.in-addr.arpa" IN {
type master;
file "10.168.192.in-addr.arpa.zone";
include "/etc/rndc.key";
[root@secinfo1 named]# cat /var/named/rede.net.hosts
$TTL 86400
$ORIGIN rede.net.
@ 1D IN SOA @ root.rede.net. (
42 ; serial (d. adams)
3H ; refresh
15M ; retry
1W ; expiry
1D ) ; minimum
1D IN NS rede.net.
1D IN A 192.168.10.1
[root@secinfo1 named]# cat 10.168.192.in-addr.arpa.zone
$TTL 86400
@ IN SOA rede.net. root.rede.net. (
1997022700 ; Serial
28800 ; Refresh
14400 ; Retry
3600000 ; Expire
86400 ) ; Minimum
IN NS rede.net.
5 IN PTR rede.net.
[root@secinfo1 arquivos]# cat /etc/hosts
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1 localhost.localdomain localhost
192.168.10.1 secinfo1.rede.net secinfo1
[root@secinfo1 arquivos]# cat /etc/rndc.conf
* Sample rndc configuration file. */
options {
default-server localhost;
default-key "rndckey";
server localhost {
key "rndckey";
[root@secinfo1 arquivos]# cat /etc/rndc.key
key "rndckey" {
algorithm hmac-md5;
secret "OioXIKD6D7S1Vglq52Xf7vFbkf300Zef39tcUd2OCUdhNCEUWGHNsZL8cTQY";
Citação
