Eu estou tentando instalar o squid e olha o que esta acontecendo:
[root@serverlinux squid-2.5.STABLE10]# ./configure --prefix=/usr/local/squid --enable-default-err-language=Portuguese
loading cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for mawk... mawk
checking whether make sets ${MAKE}... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking whether the C compiler (gcc -g) works... no
configure: error: installation or configuration problem: C compiler cannot create executables.
Alguém pode me ajudar?[/quote]
