Eae Galera...
Seguinte configurei o Proftpd em uma rede interna e estou passando por um pequeno problema.
Ele fica conectado apenas por alguns minutos e logo em seguida desconecta.
[root@contab_server proftp]# tail -f /var/proftpd/proftpd.log
Aug 10 11:42:58 contab_server proftpd[5130] contab_server: Failed binding to 0.0.0.0, port 21: Address already in use
Aug 10 11:42:58 contab_server proftpd[5130] contab_server: Check the ServerType directive to ensure you are configured correctly.
Percebi essa mensagem no log, alguém pode me ajudar?
# /etc/proftpd.conf -- This is a basic ProFTPD configuration file.
# To really apply changes reload proftpd after modifications.
ServerName "FTP_Server"
ServerType standalone
DeferWelcome off
ServerAdmin "Se detectado algum problema. E-mail [email protected]"
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayFirstChdir .message
ListOptions "-l"
DenyFilter \*.*/
WtmpLog off
SystemLog /var/proftpd/proftpd.log
DefaultRoot ~
# Uncomment this if you are using NIS or LDAP to retrieve passwords:
#PersistentPasswd off
# Uncomment this if you would use TLS module:
#TLSEngine on
# Uncomment this if you would use quota module:
#Quotas on
# Uncomment this if you would use ratio module:
#Ratios on
# Port 21 is the standard FTP port.
Port 21
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
# Set the user and group that the server normally runs at.
User nobody
Group nogroup
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask 022 022
# Normally, we want files to be overwriteable.
AllowOverwrite on
# Delay engine reduces impact of the so-called Timing Attack described in
# http://security.lss.hr/index.php?pag...LSS-2004-10-02
# It is on by default.
#DelayEngine off
# A basic anonymous configuration, no upload directories.
# <Anonymous ~ftp>
# User ftp
# Group nogroup
# # We want clients to be able to login with "anonymous" as well as "ftp"
# UserAlias anonymous ftp
# # Cosmetic changes, all files belongs to ftp user
# DirFakeUser on ftp
# DirFakeGroup on ftp
# RequireValidShell off
# # Limit the maximum number of anonymous logins
# MaxClients 10
# # We want 'welcome.msg' displayed at login, and '.message' displayed
# # in each newly chdired directory.
# DisplayLogin welcome.msg
# DisplayFirstChdir .message
# # Limit WRITE everywhere in the anonymous chroot
# <Directory *>
# <Limit WRITE>
# DenyAll
# </Limit>
# </Directory>
# # Uncomment this if you're brave.
# # <Directory incoming>
# # # Umask 022 is a good standard umask to prevent new files and dirs
# # # (second parm) from being group and world writable.
# # Umask 022 022
# # <Limit READ WRITE>
# # DenyAll
# # </Limit>
# # <Limit STOR>
# # AllowAll
# # </Limit>
# # </Directory>
# </Anonymous>
Agradeço.
[ ] 's
Bau
 Urgente FTP Disconecta sozinho.
						 Citação
  Citação
