Pessoal. Instalei o Suse 9.3 e o bichinho está com problemas. No primeiro Boot ele iniciou o Server X sem problemas mas agora ele está apresentando erro na hora de iniciar o X. Já reinstalei o sistema para resolver esse mesmo problema. Queria que de inicio ele já caisse naquela tela de login com opção de escolher qual o ambiente que quero (KDE, Gnome). como ele não está aparecendo essa tela e fica na tela para login em modo texto mesmo eu estou tentando usar o startx para iniciar. Ai aparece o erro:
Código :X Window System Version 6.8.1 Release Date: 17 September 2004 X Protocol Version 11, Revision 0, Release 6.8.1 Build Operating System: SuSE Linux [ELF] SuSE Current Operating System: Linux white-tiger 2.6.8-24-default #1 Wed Oct 6 09:16:23 UTC 2004 i686 Build Date: 04 October 2004 Before reporting problems, check http://wiki.X.Org to make sure that you have the latest version. Module Loader present Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Wed Oct 31 20:16:34 2001 (==) Using config file: "/etc/X11/xorg.conf" (EE) SIS(0): ************************************************** (EE) SIS(0): ERROR: (EE) SIS(0): Virtual screen too big for memory; 1536K needed, 1532K available (EE) SIS(0): END OF MESSAGE (EE) SIS(0): ************************************************** (EE) Screen(s) found, but none have a usable configuration. Fatal server error: no screens found Please consult the The X.Org Foundation support at http://wiki.X.Org for help. Please also check the log file at "/var/log/Xorg.0.log" for additional information. XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0" after 0 requests (0 known processed) with 0 events remaining.
Já usei o xf86config mas continua a mesma coisa. Segue o meu /etc/X11/Xorg.conf
Código :# /.../ # SaX generated X11 config file # Created on: 2005-08-10T00:29:55-0400. # # Version: 4.8 # Contact: Marcus Schaefer <[email protected]>, 2002 # # Automatically generated by [ISaX] (4.8) # PLEASE DO NOT EDIT THIS FILE! # Section "Files" FontPath "/usr/X11R6/lib/X11/fonts/misc:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/local" FontPath "/usr/X11R6/lib/X11/fonts/75dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/100dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/Type1" FontPath "/usr/X11R6/lib/X11/fonts/URW" FontPath "/usr/X11R6/lib/X11/fonts/Speedo" FontPath "/usr/X11R6/lib/X11/fonts/PEX" FontPath "/usr/X11R6/lib/X11/fonts/cyrillic" FontPath "/usr/X11R6/lib/X11/fonts/latin2/misc:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/latin2/75dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/latin2/100dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/latin2/Type1" FontPath "/usr/X11R6/lib/X11/fonts/latin7/75dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/baekmuk:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/japanese:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/kwintv" FontPath "/usr/X11R6/lib/X11/fonts/truetype" FontPath "/usr/X11R6/lib/X11/fonts/uni:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/CID" FontPath "/usr/X11R6/lib/X11/fonts/ucs/misc:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/ucs/75dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/ucs/100dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/hellas/misc:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/hellas/75dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/hellas/100dpi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/hellas/Type1" FontPath "/usr/X11R6/lib/X11/fonts/misc/sgi:unscaled" FontPath "/usr/X11R6/lib/X11/fonts/xtest" FontPath "/opt/kde3/share/fonts" InputDevices "/dev/ttyS0" InputDevices "/dev/ttyS1" InputDevices "/dev/ttyS2" InputDevices "/dev/ttyS3" InputDevices "/dev/ttyS4" InputDevices "/dev/ttyS5" InputDevices "/dev/ttyS6" InputDevices "/dev/ttyS7" InputDevices "/dev/ttyS8" InputDevices "/dev/psaux" InputDevices "/dev/logibm" InputDevices "/dev/sunmouse" InputDevices "/dev/atibm" InputDevices "/dev/amigamouse" InputDevices "/dev/atarimouse" InputDevices "/dev/inportbm" InputDevices "/dev/gpmdata" InputDevices "/dev/mouse" InputDevices "/dev/usbmouse" InputDevices "/dev/adbmouse" InputDevices "/dev/input/mice" InputDevices "/dev/input/event0" InputDevices "/dev/pointer0" InputDevices "/dev/pointer1" InputDevices "/dev/pointer2" InputDevices "/dev/pointer3" EndSection Section "ServerFlags" Option "AllowMouseOpenFail" EndSection Section "Module" Load "dbe" Load "type1" Load "freetype" Load "extmod" Load "glx" Load "v4l" EndSection Section "InputDevice" Driver "kbd" Identifier "Keyboard[0]" Option "Protocol" "Standard" Option "XkbLayout" "us_intl" Option "XkbModel" "pc105" Option "XkbRules" "xfree86" EndSection Section "InputDevice" Driver "mouse" Identifier "Mouse[1]" Option "Device" "/dev/ttyS0" Option "Emulate3Buttons" "on" Option "Name" "PLUG AND PLAY SCROLLING MOUSE" Option "Protocol" "microsoft" Option "Vendor" "Sysp" EndSection Section "Monitor" DisplaySize 280 210 HorizSync 28-54 Identifier "Monitor[0]" ModelName "LG ELECTRONICS STUDIOWORKS 5 20SI" Option "DPMS" VendorName "GSM" VertRefresh 43-90 UseModes "Modes[0]" EndSection Section "Modes" Identifier "Modes[0]" Modeline "1024x768" 73.89 1024 1224 1336 656 768 769 772 799 Modeline "800x600" 36.88 800 832 912 1024 600 601 604 621 Modeline "800x600" 44.13 800 840 920 1040 600 601 604 624 Modeline "800x600" 51.73 800 840 928 1056 600 601 604 628 Modeline "800x600" 58.73 800 840 928 1056 600 601 604 632 Modeline "640x480" 23.06 640 656 720 800 480 481 484 497 Modeline "640x480" 27.74 640 664 728 816 480 481 484 500 Modeline "640x480" 32.64 640 672 736 832 480 481 484 503 Modeline "640x480" 36.97 640 672 736 832 480 481 484 505 EndSection Section "Screen" DefaultDepth 16 SubSection "Display" Depth 15 Modes "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 32 Modes "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1024x768" "800x600" "640x480" EndSubSection Device "Device[0]" Identifier "Screen[0]" Monitor "Monitor[0]" EndSection Section "Device" BoardName "SiS630 GUI Accelerator+3D" BusID "1:0:0" Driver "sis" Identifier "Device[0]" VendorName "SiS" EndSection Section "ServerLayout" Identifier "Layout[all]" InputDevice "Keyboard[0]" "CoreKeyboard" InputDevice "Mouse[1]" "CorePointer" Option "Clone" "off" Option "Xinerama" "off" Screen "Screen[0]" EndSection Section "DRI" Group "video" Mode 0660 EndSection Section "Extensions" EndSection
Se for preciso tenho o /var/log/Xorg.0.log também mas ele está grande e acho que o post já ficou enorme.
