- PORTAS TCP e UDP
PORTAS TCP e UDP
Caros, como faço para saber o que funciona na porta 4016, pq tem um ip no meu log INPUT vindo de fora pela porta UDP 1024 e passando para TCP 4016, existem vários registros desses, o que pode ser???
Desde já agradeço!!!
vfs
Re: PORTAS TCP e UDP
Problemas !!!
Posta o seu script de firewall pra galera dar uma analisada !!!
Valeu !!!
PORTAS TCP e UDP
Ve ai pra mim, por favor, me ajuda. O que posso fazer???
Aug2410:45:05 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=12.120.1.15 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=3890
Aug2410:45:35 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=12.120.1.15 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=3890
Aug2410:45:36 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=12.120.1.15 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=3890
Aug2411:08:10 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=131.107.115.28 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4753
Aug2411:02:36 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.11 DST=200.217.105.189 PROTO=UDP SPT=53 DPT=1024 PROTO=TCP SPT=80 DPT=4604
Aug2411:02:37 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4608
Aug2411:02:38 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4608
Aug2411:02:40 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4608
Aug2411:02:40 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4609
Aug2411:02:40 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4610
Aug2411:02:40 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4611
Aug2411:02:40 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4612
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4612
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4609
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4610
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4613
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4611
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4614
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4615
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4616
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4617
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4618
Aug2411:02:41 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4619
Aug2411:02:42 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4617
Aug2411:02:42 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4618
Aug2411:02:42 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4619
Aug2411:02:42 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4616
Aug2411:02:42 LXproxy kernel: INPUTIPTABLES IN=ppp0 OUT= SRC=143.166.224.238 DST=200.217.105.189 PROTO=TCP SPT=80 DPT=4620
PORTAS TCP e UDP
O jeito mais facil de saber uma porta eh ir no google e por port numerodaporta e pronto ele te da um monte de link algum vai ter o problema nessa porta
falows
mantabodyboarder
PORTAS TCP e UDP
Segundo Dave's Port List:
Jade, Latinus, NetSpy, Remote Administration Tool - RAT [no 2]
No site da GLock Software tem mais informações sobre portas e os trojans e spys que as utilizam.
