- Resolução no X
Resolução no X
Meu XF86config está assim:
Section "ServerLayout"
Identifier "XFree86 Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
FontPath "/usr/X11R6/lib/X11/fonts/CID/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
Section "Module"
Load "dbe"
Load "dri"
Load "extmod"
Load "glx"
Load "record"
Load "xtrap"
Load "speedo"
Load "type1"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "Microsoft"
Option "Device" "/dev/mouse"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: : integer, : float, : "True"/"False",
### : "String", : " Hz/kHz/MHz"
### [arg]: arg optional
#Option "SWcursor" # []
#Option "PciRetry" # []
#Option "NoAccel" # []
#Option "SetMClk" #
#Option "MUXThreshold" #
#Option "ShadowFB" # []
#Option "Rotate" # []
#Option "VideoKey" #
#Option "NoMMIO" # []
#Option "NoPciBurst" # []
#Option "MMIOonly" # []
#Option "CyberShadow" # []
#Option "CyberStretch" # []
#Option "XvHsync" #
#Option "XvVsync" #
#Option "XvBskew" #
#Option "XvRskew" #
Identifier "Card0"
Driver "trident"
VendorName "Trident"
BoardName "CyberBlade/i7"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Onde mexo para aumentar minha resolução, visto que ela está em 640x480 para algo como 1024x768?
Obrigado pela ajuda.
Comedlinux
LinuxIT User
Resolução no X
Use o xf86config, defina modo para 16bits como numero 4, 1024x768, de Modes Are OK e prossiga normalmente.
Resolução no X
Vc tambem pode usar o Xconfigurator para configurar...
Eh simples!!!
Falows
Resolução no X
Realmente, mas Xconfigurator soh existe em distribuicoes RedHat-Like.
