Bom, nenhum usuario consegue autenticar pelo pop
vo mandar meus conf files, alguem me de uma luz <IMG SRC="images/forum/icons/icon_wink.gif">
E eu tb nao tenho o arquivo /var/log/maillog
Obrigado.
Configure do Vpopmail
./configure --enable-default-domain=bsbi.com.br \
[email protected] \
--enable-logging=y \
--enable-defaultquota=25000000S \
--enable-passwd=n \
--enable-roaming-users=y \
--enable-md5-passwords=y \
--enable-tcpserver-file=/etc/tcp.smtp \
--enable-tcprules-prog=/usr/local/bin/tcprules \
--enable-mysql=y \
--enable-sqlincdir=/usr/local/mysql/include/mysql \
--enable-sqllibdir=/usr/local/mysql/lib/mysql/lib \
--enable-auth-logging=y \
--enable-mysql-logging=y \
--enable-clear-passwd=n \
--enable-valias=y
/var/qmail/rc:
#!/bin/sh
# Using splogger to send the log through syslog.
# Using qmail-local to deliver messages to ~/Mailbox by default.
exec env - PATH="/var/qmail/bin:$PATH" \
qmail-start "`cat /var/qmail/control/defaultdelivery`"
/var/qmail/qmail-pop3/run
#!/bin/sh
exec /usr/local/bin/softlimit -m 2000000 \
/usr/local/bin/tcpserver -v -H -R -l 0 0 110 /var/qmail/bin/qmail-popup bsbi.com.br\
/var/qmail/vpopmail/bin/vchkpw /var/qmail/bin/qmail-pop3d Maildir 2>&1
/var/qmail/qmail-pop3/log/run
#!/bin/sh
exec /usr/local/bin/setuidgid qmaill /usr/local/bin/multilog t n100 s1000000 /var/log/qmail/pop3d
/var/qmail/qmail-smtpd/run
#!/bin/sh
QMAILDUID=`id -u qmaild`
NOFILESGID=`id -g qmaild`
QMAILDUID=`id -u vpopmail`
NOFILESGID=`id -g vpopmail`
MAXSMTPD=`cat /var/qmail/control/concurrencyincoming`
QMAILQUEUE="/var/qmail/bin/qmail-scanner-queue.pl"
export QMAILQUEUE
/usr/local/bin/tcpserver -v -R -l 0 -x /etc/tcp.smtp.cdb -c "$MAXSMTPD" \
-u "$QMAILDUID" -g 1004 0 smtp /var/qmail/bin/qmail-smtpd \
/var/qmail/vpopmail/bin/vchkpw /bin/true 2>&1
/var/qmail/qmail-smtpd/log/run
#!/bin/sh
exec /usr/local/bin/setuidgid qmaill /usr/local/bin/multilog t /var/log/qmail/smtpd
/var/qmail/qmail-send/run
#!/bin/sh
exec /var/qmail/rc
/var/qmail/qmail-send/log/run
#!/bin/sh
Citação
