E ae pessoal do UnderLinux...
Preciso de uma ajuda...
Eu estou tentando fazer funcionar meu moden no Slackware 10, mas está dificel...Eu tenho um intel537, e ja li várias materias sobre como instalar...Mas ta dificil...
Eu baixei o modulo no site da intel e tentei instalar...
A instalação foi assim:
Depois de digitar tar -zxvf nomedoarquivo
bash-3.00# cd intel-537EP_secure-2.60.80.0/
bash-3.00# make clean
cd coredrv; make clean
make[1]: Entering directory `/home/intel-537EP_secure-2.60.80.0/coredrv'
rm -f *.ko *.o *~ core
make[1]: Leaving directory `/home/intel-537EP_secure-2.60.80.0/coredrv'
rm -f *.o *.ko
bash-3.00# make 537
Module precompile check
Current running kernel is: 2.4.29
/lib/modules... autoconf.h exists
diff: /boot/vmlinuz.autoconf.h: No such file or directory
autoconf.h matches running kernel
diff: /boot/vmlinuz.version.h: No such file or directory
version.h matches running kernel
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o coredrv.o coredrv.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o clmmain.o clmmain.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o rts.o rts.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o task.o task.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o uart.o uart.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o wwh_dflt.o wwh_dflt.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o locks.o locks.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o softserial_io.o softserial_io.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o softserial_ioctl.o softserial_ioctl.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o softserial.o softserial.c
cc -DTARGET_CATAWBA -DTARGET_LINUX -DLINUX -Wall -O -I /lib/modules/`uname -r`/build/include -I ../inc -fno-common -DTARGET_CATAWBA -c -o afedsp_int.o afedsp_int.c
afedsp_int.c:454: warning: initialization from incompatible pointer type
strip --strip-debug 537core.lib
ld -r coredrv.o clmmain.o rts.o task.o uart.o wwh_dflt.o locks.o softserial_io.o softserial_ioctl.o softserial.o afedsp_int.o 537core.lib -o Intel537.o
bash-3.00# make install
rm -f /etc/hamregistry.bin
bash 537_inst
running kernel 2.4.29
installing hamregistry, used for persistant storage
installing usrsound, a soft buzzer
installing 537 module
seting up slackware 537_boot script
starting module and utilities
error loading Intel537
rmmod: module Intel537 is not loaded
done
Como vocês podem ver, no final ele da um erro e fala que não pode ser carregado...
Alguem pode me ajudar??
Agradeço desde ja a atenção de todos...
