- Erro no PROFTPD
Erro no PROFTPD
Alguem sabe que erro é esse ?
Iniciando proftpd: - getaddrinfo 'squid' error: Name or service not known
- warning: unable to determine IP address of 'squid'
- error: no valid servers configured
- Fatal: error processing configuration file '/etc/proftpd.conf'
OBS O nome da maquina é squid
Seguem o proftpd.conf
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "ProFTPD Default Installation"
ServerType inetd
DefaultServer on
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd).
MaxInstances 30
# Set the user and group under which the server will run.
User nobody
Group nobody
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
DefaultRoot ~ !root
# Normally, we want files to be overwriteable.
<Directory />
AllowOverwrite on
</Directory>
# A basic anonymous configuration, no upload directories. If you do not
# want anonymous users, simply delete this entire <Anonymous> section.
<Anonymous ~ftp>
User ftp
Group ftp
# We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
AnonRequirePassword off
RequireValidShell off
# Limit the maximum number of anonymous logins
MaxClients 10
# We want 'welcome.msg' displayed at login, and '.message' displayed
# in each newly chdired directory.
DisplayLogin welcome.msg
DisplayFirstChdir .message
# Limit WRITE everywhere in the anonymous chroot
<Limit WRITE>
DenyAll
</Limit>
</Anonymous>
Erro no PROFTPD
Prezado Edu pelo que vi vc esta com o seu proftp iniciando no inetd vc dele habilitar no inet para ele funcionar ou então colocalo como standalone . :@:
6)
resp proftpd
Amigo coloquei como standalone e o mesmo erro apareceu !!!!
Segue o erro abaixo
[root@squid /]# service proftpd start
Iniciando proftpd: - warning: AuthPAMAuthoritative is deprecated
[FALHOU]
Erro no PROFTPD
bom nao tenho squid aqui configurado mais como no teu erro tem uma citação a ele , desativa ele pra ver e depois roda o proftpd pra ver se vai rodar !!
informa o que houve ok
Erro no PROFTPD
vc tem squid rodando tbem se tiver vc vai ter que habilitar a porta no squid :@:
6)
Erro no PROFTPD
FTP independe de Proxy
isso ai é um algum erro na config do proftpd, como vc instalou ele? nunca tive problemas com ele.
Outro pronto, qual é o noem da sua maquina?? "squid" por acaso???? verifique o seu /etc/hosts e mostre para gente
Erro no PROFTPD
segue o /etc/hosts
eu instalei baixando um pacote rpm dele pro fedora 4
http://dag.wieers.com/packages/proftpd
login as: root
[email protected]'s password:
Last login: Tue Sep 19 15:08:30 2006 from aca80064.ipt.aol.com
[[root@squid ~]# mcedit /etc/hosts
/etc/hosts [----] 0 L:[ 1+ 3 4/ 4] *(146 / 146b)= <EOF>
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1 localhost.localdomain localhost
Erro no PROFTPD
tente por uma linha lá..
ip.do.seu.servidor squid
ou por local depois do localhost , a palavra squid
tente isso.
