- Horde3/imp4/turba2.2
Aew Galera..
Següenteee..
Instalei o Horde3 com o Imp4 para webmail.. até aí beleza.. ele ta funcionando que é uma magavilha.. só o problema é com o turba.. o gerenciador de contatos... escolhi a opcao pra ele gravar no mysql.. no meu caso.. o sources.php ficou da seguinte forma:
*sources.php
<?php
$cfgSources['localsql'] = array(
'title' => _("My Addressbook"),
'type' => 'sql',
// The default connection details are pulled from the Horde-wide SQL
// connection configuration.
// The old example illustrates how to use an alternate database
// configuration.
// New Example:
'params' => array_merge($conf['sql'], array('table' => 'turba_objects')),
// Old Example:
// 'params' => array(
// 'phptype' => 'mysql',
// 'hostspec' => 'localhost',
// 'username' => 'horde',
// 'password' => '*****',
// 'database' => 'horde',
// 'table' => 'turba_objects',
// 'charset' => 'iso-8859-1'
'map' => array(
'__key' => 'object_id',
'__owner' => 'owner_id',
'__type' => 'object_type',
'__members' => 'object_members',
'__uid' => 'object_uid',
'name' => 'object_name',
'email' => 'object_email',
'alias' => 'object_alias',
'homeAddress' => 'object_homeaddress',
'workAddress' => 'object_workaddress',
'homePhone' => 'object_homephone',
'workPhone' => 'object_workphone',
'cellPhone' => 'object_cellphone',
'fax' => 'object_fax',
'title' => 'object_title',
'company' => 'object_company',
'notes' => 'object_notes',
'pgpPublicKey' => 'object_pgppublickey',
'smimePublicKey' => 'object_smimepublickey',
'freebusyUrl' => 'object_freebusyurl'
'search' => array(
'name',
'email'
'strict' => array(
'object_id',
'owner_id',
'object_type',
'public' => false,
'readonly' => false,
'admin' => array(),
'export' => true
$cfgSources['prefs'] = array(
'title' => _("Private Address Book"),
'type' => 'prefs',
'params' => array(
'name' => 'prefs',
'charset' => NLS::getCharset()
'map' => array(
'__key' => 'id',
'__type' => '_type',
'__members' => '_members',
'__uid' => 'uid',
'name' => 'name',
'email' => 'mail',
'alias' => 'alias'
'search' => array(
'name',
'email',
'alias'
'strict' => array(
'id',
'_type',
'public' => false,
'export' => true
Só que a bagaça é a seguinte... meus contatos são adicionados e tudo mais.. só que ele fica compartilhado entre todos os clientes do webmail.. ou seja.. eu adiciono um contato.. e todos os outros conseguem vê-lo..
Entao.. gostaria de saber se alguem ja instalou e se deu o mesmo pau.. ou sabe o que eu to fazendo de errado?!
Valeu Under's!
