:toim:
Seguinte pessoal, eu liberei gravaçao para o o samba.. dei um chown nobody.nobody e depois chmod 0777 para liberar a pasta... tirei o valid users e coloquei guest ok = yes e nada !!!
# smb.conf is the main Samba configuration file. You find a full commented
# version at /usr/share/doc/packages/samba/examples/smb.conf.SUSE if the
# samba-doc package is installed.
# Date: 2005-03-22
[global]
workgroup = OPEN
printing = cups
printcap name = cups
printcap cache time = 750
cups options = raw
printer admin = @ntadmin, root, administrator
username map = /etc/samba/smbusers
map to guest = Bad User
include = /etc/samba/dhcp.conf
logon path = \\%L\profiles\.msprofile
logon home = \\%L\%U\.9xprofile
logon drive = P:
os level = 500
idmap gid = 10000-20000
idmap uid = 10000-20000
add machine script = /usr/sbin/useradd -c Machine -d /var/lib/nobody -s /bin/false %m$
domain logons = No
domain master = No
security = user
[homes]
comment = Home Directories
valid users = %S
browseable = No
read only = No
inherit acls = Yes
[profiles]
comment = Network Profiles Service
path = %H
read only = No
store dos attributes = Yes
create mask = 0600
directory mask = 0700
[users]
comment = All users
path = /home
read only = No
inherit acls = Yes
veto files = /aquota.user/groups/shares/
## Share disabled by YaST
# [groups]
# comment = All groups
# path = /home/groups
# read only = No
# inherit acls = Yes
[printers]
comment = All Printers
path = /var/tmp
printable = Yes
create mask = 0600
browseable = No
[print$]
comment = Printer Drivers
path = /var/lib/samba/drivers
write list = @ntadmin root
force group = ntadmin
create mask = 0664
directory mask = 0775
[comun]
comment = linux
path = /home/comun/
read only = No
guest ok = yes
security = SHARE
writable = yes
avaliable = yes
ta assim...
o que eu faço agora ? quando eu conecto o banco de dados do programa internto nossa da empresa na maquina windows e mando acessar no linux fala que eu nao tenho permissao para gravar no banco de dados
alguem sabe o que pode ser ?
Citação
