- Compilação do kernel 2.6
Estou tentando atualizar o meu kernel, mas obtenho o seguinte erro ao fazer make menuconfig:
# make menuconfig
HOSTCC scripts/kconfig/mconf.o
scripts/kconfig/mconf.c:91: error: static declaration of 'current_menu' follows non-static declaration
scripts/kconfig/lkc.h:63: error: previous declaration of 'current_menu' was here
make[1]: ** [scripts/kconfig/mconf.o] Erro 1
make: ** [menuconfig] Erro 2
Será que falta alguma pacote?versão do gcc (meu gcc é versão 4)?
Cara de fato é preciso as bibliotecas gcc....
Qual a sua distro....!!!!
Tenta instalar as bibliotecas gcc e tenta novamente!!!!!
[ ]´s
Bau
É o gcc
Minha distro é o debian, mas...
Pesquisei um pouco mais no google e olha só:
On Tue, Jul 19, 2005 at 08:13:41PM -0400, Andres Salomon wrote:
On Tue, 19 Jul 2005 23:49:12 +0200, Daniel Leidert wrote:
Package: kernel-source-2.6.8
Version: 2.6.8-16
Severity: grave
Justification: renders package unusable
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
The kernel does not compile with gcc 4.0:
was here
make[1]: *** [scripts/kconfig/mconf.o] Error 1
make: *** [xconfig] Error 2
Uh, right.. Horms, would you prefer to keep 2.6.8 in unstable for working
on security stuff, or can we remove it?
I'd like to keep it there. I'll take a look into how bad
the gcc-4.0 issues are here. If its too painful, I guess
we should pull 2.6.8 from unstable.
Ou seja, o problema é o gcc4, até agora está indo bacan com o kernel 2.6.12
