Colegas,
Quando carrego o VNCSERVER aparentemente fica tudo certinho, mas quando tento faz o acesso ao servidor, na dá certo. O que pode está acontecendo?
O Log do VNCSERVER tá com a seguinte mensagem:
05/11/05 15:51:19 Xvnc version 3.3.6 - built Nov 26 2002 15:19:26
05/11/05 15:51:19 Copyright (C) 2002 RealVNC Ltd.
05/11/05 15:51:19 Copyright (C) 1994-2000 AT&T Laboratories Cambridge.
05/11/05 15:51:19 All Rights Reserved.
05/11/05 15:51:19 See http://www.realvnc.com for information on VNC
05/11/05 15:51:19 Desktop name 'X' (medonho.homedomain:1)
05/11/05 15:51:19 Protocol version supported 3.3
05/11/05 15:51:19 Listening for VNC connections on TCP port 5901
05/11/05 15:51:19 Listening for HTTP connections on TCP port 5801
05/11/05 15:51:19 URL http://medonho.homedomain:5801
failed to set default font path '/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/Speedo/,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/'
Fatal server error:
could not open default font 'fixed'
xsetroot: unable to open display 'medonho.homedomain:1'
Warning: This program is an suid-root program or is being run by the root user.
The full text of the error or warning message cannot be safely formatted
in this environment. You may get a more descriptive message by running the
program as a non-root user or by removing the suid bit on the executable.
xterm Xt error: Can't open display: %s
twm: unable to open display "medonho.homedomain:1"
Dei uma olhada mas não consegui entender.
Fico muito agradecido a quem puder ajudar.
