Linux version 2.6.11-1.1369_FC4 ([email protected]) (gcc version 4.0.0 20050525 (Red Hat 4.0.0-9)) #1 Thu Jun 2 22:55:56 EDT 2005
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000007eae000 (usable)
BIOS-e820: 0000000007eae000 - 0000000008000000 (reserved)
BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
126MB LOWMEM available.
Using x86 segment limits to approximate NX protection
On node 0 totalpages: 32430
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 28334 pages, LIFO batch:15
HighMem zone: 0 pages, LIFO batch:1
DMI 2.3 present.
ACPI: RSDP (v000 DELL ) @ 0x000fd790
ACPI: RSDT (v001 DELL GX100 0x00000007 ASL 0x00000061) @ 0x000fd7a4
ACPI: FADT (v001 DELL GX100 0x00000007 ASL 0x00000061) @ 0x000fd7cc
ACPI: DSDT (v001 DELL dt_ex 0x00001000 MSFT 0x0100000b) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
Allocating PCI resources starting at 08000000 (gap: 08000000:f7b00000)
Built 1 zonelists
Kernel command line: ro root=LABEL=/
Initializing CPU#0
CPU 0 irqstacks, hard=c0457000 soft=c0456000
PID hash table entries: 1024 (order: 10, 16384 bytes)
Detected 595.137 MHz processor.
Using pmtmr for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 123180k/129720k available (2518k kernel code, 6024k reserved, 690k data, 180k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 1175.55 BogoMIPS (lpj=587776)
Security Framework v1.0.0 initialized
SELinux: Initializing.
SELinux: Starting in permissive mode
selinux_register_security: Registering secondary module capability
Capability LSM initialized as secondary
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 128K
CPU: After all inits, caps: 0383f1ff 00000000 00000000 00000040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel Celeron (Coppermine) stepping 06
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
ACPI: setting ELCR to 0200 (from 0e20)
checking if image is initramfs... it is
softlockup thread 0 started up.
Freeing initrd memory: 1108k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfc0be, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20050309
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:00:01.0
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 15)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 12 devices
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
pnp: 00:0b: ioport range 0x800-0x85f could not be reserved
pnp: 00:0b: ioport range 0xc00-0xc7f has been reserved
pnp: 00:0b: ioport range 0x860-0x8ff could not be reserved
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1133438923.414:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux: Registering netfilter hooks
Initializing Cryptographic API
ksign: Installing public key data
Loading keyring
- Added public key 42BD35A990375F72
- User ID: Red Hat, Inc. (Kernel Module GPG key)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected an Intel i810 DC100 Chipset.
agpgart: detected 4MB dedicated video ram.
agpgart: AGP aperture is 64M @ 0xf8000000
PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 76 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH: IDE controller at PCI slot 0000:00:1f.1
ICH: chipset revision 2
ICH: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
hda: Maxtor 90651U2, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: SAMSUNG CD-ROM SC-148F, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 12594960 sectors (6448 MB) w/512KiB Cache, CHS=12495/16/63, UDMA(66)
hda: cache flushes not supported
hda: hda1 hda2 hda3 hda4 < hda5 >
hdc: ATAPI 48X CD-ROM drive, 128kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ide-floppy driver 0.99.newide
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
mice: PS/2 mouse device common for all mice
md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 128 buckets, 4Kbytes
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
Initializing IPsec netlink socket
NET: Registered protocol family 17
ACPI wakeup devices:
PCI0 USB0 PCI1 KBD
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 180k freed
input: AT Translated Set 2 keyboard on isa0060/serio0
device-mapper: 4.4.0-ioctl (2005-01-12) initialised: [email][email protected][/email]
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
Floppy drive(s): fd0 is 1.44M
FDC 0 is a National Semiconductor PC87306
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI Interrupt 0000:01:0c.0[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
3c59x: Donald Becker and others. [url]www.scyld.com/network/vortex.html[/url]
0000:01:0c.0: 3Com PCI 3c905C Tornado at 0xec80. Vers LK1.1.19
i801_smbus 0000:00:1f.3: enabling SMBus device
hw_random hardware driver 1.0.0 loaded
USB Universal Host Controller Interface driver v2.2
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:1f.2[D] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1f.2 to 64
uhci_hcd 0000:00:1f.2: UHCI Host Controller
uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1f.2: irq 11, io base 0x0000ff80
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: Power Button (FF) [PWRF]
ibm_acpi: ec object not found
md: Autodetecting RAID arrays.
md: could not bd_claim hda1.
md: autorun ...
md: considering hda5 ...
md: adding hda5 ...
md: hda3 has different UUID to hda5
md: adding hda2 ...
md: created md1
md: bind<hda2>
md1: WARNING: hda5 appears to be on the same physical disk as hda2. True
protection against single-disk failure might be compromised.
md: bind<hda5>
md: running: <hda5><hda2>
md: raid1 personality registered as nr 3
raid1: raid set md1 active with 2 out of 2 mirrors
md: considering hda3 ...
md: adding hda3 ...
md: created md0
md: bind<hda3>
md: running: <hda3>
raid1: raid set md0 active with 1 out of 2 mirrors
md: ... autorun DONE.
EXT3 FS on hda1, internal journal
Bluetooth: Core ver 2.7
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.7
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM ver 1.5
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
lp0: using parport0 (interrupt-driven).
lp0: console ready
NET: Registered protocol family 10
Disabled Privacy Extensions on device c03e6820(lo)
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
