Pessoal, configurei o squid e gostaria que alguem desse uma olhada, alguma sugestão, enfim se está tudo certo com ele...
Se a ordem das acl's batem e tal...
SQUID.CONF
http_port 3128
acl QUERY urlpath_regex cgi-bin \? no_cache deny QUERY
#Definindo memória,cash e afins...
cache_mem 64 MB
maximum_object_size_in_memory 64 KB
maximum_object_size_in_memory 200 KB
minimum_object_size 0 KB
cache_swap_low 90
cache_swap_high 95
cache_dir ufs /var/spool/squid 10000 16 256
client_netmask 255.255.255.255
refresh_pattern ^ftp: 60 20% 2280
refresh_pattern ^gopher: 60 0% 2280
refresh_pattern . 60 20% 2280
#Criando as acls
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl CONNECT method CONNECT
http_access deny manager
http_access deny !Safe_ports
#Bloqueando palavras chaves dentro destes arquivos
acl blockedsites url_regex -i "/etc/squid/bloqueados/block.txt"
acl unblockedsites url_regex -i "/etc/squid/bloqueados/unblock.txt"
http_access deny blockedsites !unblockedsites
#Bloqueando mp3,.iso e sh
acl mp3 url_regex -i.*.mp3$
http_access deny mp3
acl iso url_regex -i.*.iso$
http_access deny iso
acl sh url_regex -i.*.sh$
http_access deny sh
acl redelocal src 192.168.2.0/24
http_access allow localhost
http_access allow redelocal
http_access deny all
#Proxy Transparente
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
icp_access allow all
miss_access allow all
visible_hostname GTIS
coredump_dir /var/spool/squid
