olá pessoal ...instalei o cbq mais ele não está limitando banda
segue mes arquivos e os status
cbq-0002.teste.in
DEVICE=eth0,100Mbit,10Mbit
RATE=10Kbit
WEIGHT=1Kbit
PRIO=5
RULE=192.168.2.10
BOUNDED=yes
ISOLATED=yes
cbq-0002.teste.out
DEVICE=eth1,100Mbit,10Mbit
RATE=10Kbit
WEIGHT=1Kbit
PRIO=5
RULE=192.168.2.10,
BOUNDED=yes
ISOLATED=yes
Logs,
./cbq compile
[root@recife init.d]# ./cbq compile
tc qdisc del dev eth0 root
tc qdisc add dev eth0 root handle 1 cbq bandwidth 100Mbit avpkt 1000 cell 8
tc class change dev eth0 root cbq weight 10Mbit allot 1514
tc qdisc del dev eth1 root
tc qdisc add dev eth1 root handle 1 cbq bandwidth 100Mbit avpkt 1000 cell 8
tc class change dev eth1 root cbq weight 10Mbit allot 1514
tc class add dev eth0 parent 1: classid 1:2 cbq bandwidth 100Mbit rate 10Kbit weight 1Kbit prio 5 allot 1514 cell 8 maxburst 20 avpkt 1000 bounded isolated
tc qdisc add dev eth0 parent 1:2 handle 2 tbf rate 10Kbit buffer 10Kb/8 limit 15Kb mtu 1500
tc filter add dev eth0 parent 1:0 protocol ip prio 100 u32 match ip dst 192.168.2.10 classid 1:2
tc class add dev eth1 parent 1: classid 1:2 cbq bandwidth 100Mbit rate 10Kbit weight 1Kbit prio 5 allot 1514 cell 8 maxburst 20 avpkt 1000 bounded isolated
tc qdisc add dev eth1 parent 1:2 handle 2 tbf rate 10Kbit buffer 10Kb/8 limit 15Kb mtu 1500
tc filter add dev eth1 parent 1:0 protocol ip prio 100 u32 match ip src 192.168.2.10 classid 1:2
log stats
[root@recife init.d]# ./cbq stats
### eth0: queueing disciplines
qdisc cbq 1: rate 100Mbit (bounded,isolated) prio no-transmit
Sent 1266 bytes 11 pkts (dropped 0, overlimits 0 requeues 0)
borrowed 0 overactions 0 avgidle 79 undertime 0
qdisc tbf 2: parent 1:2 rate 10Kbit burst 10Kb lat 4.0s
Sent 0 bytes 0 pkts (dropped 0, overlimits 0 requeues 0)
### eth0: traffic classes
class cbq 1: root rate 100Mbit (bounded,isolated) prio no-transmit
Sent 2466 bytes 19 pkts (dropped 0, overlimits 0 requeues 0)
borrowed 0 overactions 0 avgidle 81 undertime 0
class cbq 1:2 parent 1: leaf 2: rate 10Kbit (bounded,isolated) prio 5
borrowed 0 overactions 0 avgidle 2.32491e+07 undertime 0
class tbf 2:1 parent 2:
### eth0: filtering rules
filter parent 1: protocol ip pref 100 u32
filter parent 1: protocol ip pref 100 u32 fh 800: ht divisor 1
filter parent 1: protocol ip pref 100 u32 fh 800::800 order 2048 key ht 800 bkt 0 flowid 1:2 (rule hit 29 success 0)
match c0a8020a/ffffffff at 16 (success 0 )
### eth1: queueing disciplines
Sent 113 bytes 2 pkts (dropped 0, overlimits 0 requeues 0)
### eth1: traffic classes
### eth1: filtering rules
filter parent 1: protocol ip pref 100 u32 fh 800::800 order 2048 key ht 800 bkt 0 flowid 1:2 (rule hit 2 success 0)
match c0a8020a/ffffffff at 12 (success 0 )
### eth2: queueing disciplines
qdisc pfifo_fast 0: bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
Sent 83231442 bytes 112273 pkts (dropped 0, overlimits 0 requeues 0)
O QUE ESTÁ ERRADO >>> ???????????????????????????????/
