Galera to tendo uma dor de cabeça pra instalar o postfix , uso o slack 10.1 tenho as bibliotecas gcc instaladas e atualizadas..
da este erro no make
gcc -Wmissing-prototypes -Wformat -DHAS_MYSQL -I/usr/include/mysql -DHAS_PCRE -g -O -I. -I../../include -DLINUX2 -o master master.o master_conf.o master_ent.o master_sig.o master_avail.o master_spawn.o master_service.o master_status.o master_listen.o master_vars.o master_wakeup.o master_flow.o ../../lib/libglobal.a ../../lib/libutil.a /usr/lib/mysql -lmysqlclient -lz -lm -L/usr/lib -L/usr/lib -lpcre -ldb -lnsl -lresolv
/usr/lib/mysql: file not recognized: Is a directory
collect2: ld returned 1 exit status
make: *** [master] Error 1
make: *** [update] Error 1
aqui esta as minhas libs ..
root@servermail:/opt/postfix-2.2.3# slackpkg search gcc
The list below shows all packages with the selected pattern.
[uninstalled] - x11-6.8.1-i486-4
[ installed ] - aaa_elflibs-10.1.0-i486-1
[uninstalled] - zsh-4.2.1-i486-1
[ installed ] - gcc-3.3.4-i486-1
[ installed ] - gcc-g++-3.3.4-i486-1
[ installed ] - gcc-g77-3.3.4-i486-1
[ installed ] - gcc-gnat-3.3.4-i486-2
[ installed ] - gcc-java-3.3.4-i486-1
[ installed ] - gcc-objc-3.3.4-i486-1
[ installed ] - kernel-source-2.4.29-noarch-1
[uninstalled] - kdevelop-3.1.2-i486-1
[uninstalled] - qt-3.3.3-i486-3
[ installed ] - jre-1_5_0_01-i586-1
[uninstalled] - x11-6.8.1-i486-3
[uninstalled] - x11-docs-html-6.8.1-noarch-2
[uninstalled] - j2sdk-1_5_0_01-i586-1
o que vcs acham o deve ser ??
grato!
Citação
