- problema com net adsl
alguem saberia me ajudar..
uso o suse 10 com um modem usb o dslink 180u vejam o que deu depois q instale o pacote rp-pppoe-3.7.tar.gz
linux:/home/reifison # adictrl -i
bash: adictrl: command not found
linux:/home/reifison # eciadsl-config-tk
linux:/home/reifison # eciadsl-start
[EciAdsl 1/5] Setting up USB support...
Preliminary USB device filesystem is OK
[EciAdsl 2/5] Uploading firmware...
Process skipped .. no more needed
firmware loaded successfully
[EciAdsl 3/5] Synchronization...
ERROR eciadsl-synch SYNCHING: failed
ERROR eciadsl-synch: failed
Synchronization successful
[EciAdsl 4/5] Connecting to provider...
using channel 23
Using interface ppp0
Connect: ppp0 <--> /dev/pts/2
sent [LCP ConfReq id=0x1 <magic 0x4a5652e4>]
Script /usr/bin/eciadsl-pppoeci -vpi 0 -vci 35 -vendor 0x1690 -product 0x0212 -mode VCM_RFC2364 finished (pid 29323), status = 0x0
Modem hangup
Connection terminated.
using channel 24
sent [LCP ConfReq id=0x2 <magic 0x9f603f3c>]
Script /usr/bin/eciadsl-pppoeci -vpi 0 -vci 35 -vendor 0x1690 -product 0x0212 -mode VCM_RFC2364 finished (pid 13778), status = 0x0
Modem hangup
using channel 25
sent [LCP ConfReq id=0x3 <magic 0x9f7b2cbd>]
Script /usr/bin/eciadsl-pppoeci -vpi 0 -vci 35 -vendor 0x1690 -product 0x0212 -mode VCM_RFC2364 finished (pid 29812), status = 0x0
Modem hangup
