Sistema instaldo: Slackware 10.1
kernel 2.4.29
Bibliotecas GCC todas instaladas
to com o Ncurses tb instalado
Estou com o cbq pronto pra rodar mais acabei de descobrir que tenho que compilar o kernel , mais dentro de /usr/src/linux (link simbolico)
dou o seguinte comando basico: make menu config e me aparece isso
root@slacklinux:/usr/src/linux# make menuconfig
rm -f include/asm
( cd include ; ln -sf asm-i386 asm)
make -C scripts/lxdialog all
make[1]: Entering directory `/usr/src/linux-2.4.29/scripts/lxdialog'
/usr/lib/gcc-lib/i486-slackware-linux/3.3.4/../../../../i486-slackware-linux/bin/ld: cannot find -lc
collect2: ld returned 1 exit status
>> Unable to find the Ncurses libraries.
>> You must have Ncurses installed in order
>> to use 'make menuconfig'
make[1]: *** [ncurses] Error 1
make[1]: Leaving directory `/usr/src/linux-2.4.29/scripts/lxdialog'
make: *** [menuconfig] Error 2
Qual a dicas de vcs adms ?
