- Dual Headd
Dual Headd
Pessoal, tenho duas placas de video, sendo uma Nvidia Gxforce 5700 (AGP) e uma matrox MGA 2064W (PCI).
Seguindo o tutorial do guia do hardware
http://www.guiadohardware.net/artigos/267/
Tentei fazer um dual head aqui no meu Debian Sarge, mas não funcionou...
Segue a configuração do X:
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" RightOf "Screen0"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "ServerFlags"
Option "Xinerama" "true"
Option "AllowMouseOpenFail" "true"
EndSection
Section "Files"
# local font server
# if the local font server has problems, we can fall back on these
FontPath "unix/:7100"
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "abnt2"
Option "XkbLayout" "br"
Option "XkbVariant" "abnt2"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
Identifier "Monitor Genérico"
HorizSync 30.0 - 96.0
VertRefresh 50.0 - 160.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
HorizSync 40 - 90.0
VertRefresh 60.0 - 90
# Option "DPMS"
EndSection
Section "Device"
Identifier "Placa de Vídeo Genérica"
Driver "nvidia"
EndSection
Section "Device"
Identifier "Card1"
Driver "mga"
VendorName "Matrox Graphics, Inc."
BoardName "MGA 2064W [Millennium]"
BusID "PCI:3:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Placa de Vídeo Genérica"
Monitor "Monitor Genérico"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1600x1200" "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Card1"
Monitor "Monitor1"
DefaultDepth 1
Depth 1
Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
E nesta configuração ele me retorna o seguinte erro:
Given depth (1) is not supported by this driver
Se eu retiro esta opção de DefaultDepth ele Não inicia nenhuma das duas placas, bagunçãndo a tela.
Re: Dual Headd
issu que da usar material de fora da underlinux heheeh
ve meu artigo ae, a conf tem uns detalhes diferentes que podem ta fazendo diferenca no teu caso
https://under-linux.org/wiki/Tutoriais/X/2monitores
e ve isso aqui tb:
https://under-linux.org/component/op.../topic,27459.0
e tira fora esses depth abaixo de 8, vc nao vai querer usar 8bits de cores neh? :P
Re: Dual Headd
Valeu Ice,
Hoje a noite vou brincar com isto, ai eu posto o resultado.
[]'s
P.s.: Aprendi a lição, não fujo mais do Under.
Mais uma coisa...
Eu não recebi a notificação de resposta.
Re: Dual Headd
da uma entrada no seu perfil denovo e veja se esta habilitado tudo certinho
Re: Dual Headd
Ice, quanto a receber as notificações, está tudo normalizado, realmente faltava algumas opções.
E quanto aos monitores perfeito! Eu realmente não queria o desktop esticado, já que meu monitores possuem tamanhos diferentes (17 e 15), então criei dois desktops.
Da configuração acima eu alterei o defaultdepth para 24 no screen1 e retirei o ServerFlags.
Funcionou perfeitamente.
Re: Dual Headd
heheh
exatamente o mesmo caso de qdo fiz o artigo, 1 17 e 1 15
