- VSFTPD !!! UPLOAD !!!
Olá galera estou usando o Fedora com VSFTPD, configurei tudo até consigo logar e listar o diretorio, mas nao consigo criar nada dentro dele e nem apagar.
Ja verifiquei as permissões dei chmod 777 p/ testar , deixei o grupo identifico com acesso e nada.
Alguem poderia dar um Help !!!??
Valeu
Edu
Re: VSFTPD !!! UPLOAD !!!
Dá uma olhada pra descobrir se no seu vsftpd.conf você possui a seuinte linha:
Abraços!
Amigo, ja estava ativado essa opção e mesmo assim nao funciona, até conectei com o usuario via ssh e pelo ssh ele consegue criar e deletar no diretorio so via ftp que não !!!
o q será???
abaixo meu vsftpd.conf:
write_enable=YES
# Uncomment this to allow local users to log in.
#local_root=/var/ftp
local_enable=YES
# Uncomment this to enable any form of FTP write command.
write_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
local_umask=022
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
# Uncomment this if you want the anonymous FTP user to be able to create
# new directories.
#anon_mkdir_write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
#chown_uploads=YES
#chown_username=whoever
# You may override where the log file goes if you like. The default is shown
# below.
#xferlog_file=/var/log/vsftpd.log
chroot_local_user=YES
chroot_list_enable=YES
# (default follows)
chroot_list_file=/etc/vsftpd/ftpusers
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
#ftpd_banner=FTP SERVER EMPRESA
pam_service_name=vsftpd
#userlist_enable=YES
#enable for standalone mode
listen=YES
write_enable=YES
tcp_wrappers=YES
