ola a todos
pessoal tenho o seguinte script de htb logo abaixo, e ta me ocorrendo o seguinte.
essa regra filter:
tc filter add dev ppp0 parent 1:0 protocol ip prio 1 u32 match ip dst 192.168.0.8 flowid 1:10
tc filter add dev ppp0 parent 1:0 protocol ip prio 1 u32 match ip src 192.168.0.8 flowid 1:10
deveria de sair pela essa classe:
tc class add dev ppp0 parent 1:0 classid 1:10 htb rate 15kbps ceil 35kbps
so que nao esta, essa regra filter ta saindo pelo default sendo que o flowid é 1:10, e detalhe o restante das outra classes e filtes estao funcionando normal, so essa ai que nao esta, e ja mexi, remexi e nao resolve, se que tem algo de errado???alguem ja passou por esse problema? que possa me da uma dica?
tc qdisc del dev ppp0 root
tc qdisc add dev ppp0 root handle 1: htb default 50
tc class add dev ppp0 root classid 1:0 htb rate 35kbps ceil 35kbps
tc class add dev ppp0 parent 1:0 classid 1:20 htb rate 5kbps ceil 20kbps
tc class add dev ppp0 parent 1:0 classid 1:30 htb rate 5kbps ceil 20kbps
tc class add dev ppp0 parent 1:0 classid 1:40 htb rate 5kbps ceil 10kbps
tc class add dev ppp0 parent 1:0 classid 1:50 htb rate 5kbps ceil 5kbps
tc qdisc add dev ppp0 parent 1:10 handle 10: sfq perturb 10
tc qdisc add dev ppp0 parent 1:20 handle 20: sfq perturb 10
tc qdisc add dev ppp0 parent 1:30 handle 30: sfq perturb 10
tc qdisc add dev ppp0 parent 1:40 handle 40: sfq perturb 10
tc qdisc add dev ppp0 parent 1:50 handle 50: sfq perturb 10
tc filter add dev ppp0 parent 1:0 protocol ip prio 1 u32 match ip tos 0x10 0xff flowid 1:10
tc filter add dev ppp0 parent 1:0 protocol ip prio 3 u32 match ip dport 25 0xfff flowid 1:20
tc filter add dev ppp0 parent 1:0 protocol ip prio 3 u32 match ip dport 53 0xfff flowid 1:20
tc filter add dev ppp0 parent 1:0 protocol ip prio 3 u32 match ip dport 110 0xfff flowid 1:20
tc filter add dev ppp0 parent 1:0 protocol ip prio 3 u32 match ip dport 2095 0xfff flowid 1:20
tc filter add dev ppp0 parent 1:0 protocol ip prio 2 u32 match ip dport 80 0xfff flowid 1:30
tc filter add dev ppp0 parent 1:0 protocol ip prio 2 u32 match ip dport 443 0xfff flowid 1:30
tc filter add dev ppp0 parent 1:0 protocol ip prio 4 u32 match ip src 192.168.0.5 flowid 1:40
tc filter add dev ppp0 parent 1:0 protocol ip prio 4 u32 match ip dst 192.168.0.5 flowid 1:40
tc filter add dev ppp0 parent 1:0 protocol ip prio 4 u32 match ip src 192.168.0.6 flowid 1:40
tc filter add dev ppp0 parent 1:0 protocol ip prio 4 u32 match ip dst 192.168.0.6 flowid 1:40
Citação
