visible_hostname frlinux
http_port 3128
hierarchy_stoplist cgi-bin ?
no_cache deny QUERY
cache_mem 8 MB
cache_swap_low 90
cache_swap_high 95
maximum_object_size 4096 KB
minimum_object_size 0 KB
maximum_object_size_in_memory 8 KB
ipcache_size 1024
ipcache_low 90
ipcache_high 95
cache_dir ufs /var/spool/squid 100 16 256
cache_log /var/log/squid/cache.log
cache_store_log /var/log/squid/store.log
ftp_user Squid@
hosts_file /etc/hosts
refresh_pattern . 0 20% 4320
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563 # https, snews
acl SSL_ports port 873 # rsync
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 631 # cups
acl Safe_ports port 873 # rsync
acl purge method PURGE
acl CONNECT method CONNECT
http_access deny manager
http_access deny purge
http_access deny !Safe_ports
http_access allow CONNECT !SSL_ports
acl REDE src 192.168.0.0
http_access allow REDE
http_access allow localhost
http_access deny all
http_reply_access allow all
icp_access allow all
httpd_accel_port 80
httpd_accel_host virtual
httpd_accel_with_proxy on
