Ola!
Meu squid rondando sobre CentOS 4.3 e fazendo uma NAT, ta bloqueando o acesso a algumas radios online (ex: UOL), sera o que é? abaixo esta meu squid.conf.
# CONFIGURACAO DO SQUID
http_port 3128
visible_hostname intranet-ibsol
# Configuracao do cache
cache_mem 64 MB
maximum_object_size_in_memory 64 KB
maximum_object_size 25 MB
minimum_object_size 0 KB
cache_swap_low 90
cache_swap_high 95
cache_dir ufs /var/spool/squid/ 5120 16 256
# Localizacao do log de acesso do Squid
cache_log /var/log/squid/cache.log
cache_store_log /var/log/squid/store.log
refresh_pattern . 10 20% 2280
acl all src 172.16.0.0/255.255.255.0
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 901 # swat
acl purge method PURGE
acl CONECT method CONECT
http_access deny manager
http_access deny purge
http_access !Safe_port
http_access deny CONECT !SSL_ports
# Libera para a rede local
acl redelocal src 172.16.0.0/24
http_access allow localhost
http_access allow redelocal
# Bloqueia acesso externo
http_access deny all
# Proxy transparente
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
O que pode ser?
