Olá pessoal,
estou compilando o apache2+php5, só que est´[a me dando o seguinte erro.
Já compilei o apache e está funcionando blz, mas o php5 está me dando o seguinte erro:
Sorry, I cannot run apxs. Possible reasons follow:
1. Perl is not installed
2. apxs was not found. Try to pass the path using --with-apxs2=/path/to/apxs
3. Apache was not built using --enable-so (the apxs usage page is displayed)
The output of /usr/local/apache2/bin/apxs follows:
cannot open /var/log/apache2/build/config_vars.mk: No such file or directory at /usr/local/apache2/bin/apxs line 218.
configure: error: Aborting
root@web1:/opt/php-5.1.4# vi /usr/local/apache2/bin/apxs
reading /usr/local/apache2/bin/apxs
Isso é o que tem no arquivo "apxs" line 218:
sub get_config_vars{
my ($file, $rh_config) = @_;
open IN, $file or die "cannot open $file: $!"; => line 218
while (<IN>){
if (/^\s*(.*?)\s*=\s*(.*)$/){
$rh_config->{$1} = $2;
close IN;
Alguém pode me ajudar?
