depois de instalar o ldap e tentar startar o serviço com o comando ./slapd start
aparece a seguinte mensagem:
* Starting ldap-server ... [ !! ]
sendo que no log messages aparece o seguinte erro:
Aug 23 19:19:57 zeus slapd[11109]: No passwd entry for user ldap
o meu arquivo slapd.conf esta da seguinte forma:
# See slapd.conf(5) for details on configuration options.
# This file should NOT be world readable.
include /etc/openldap/schema/core.schema
# Define SSL and TLS properties (optional)
#TLSCertificateFile /etc/ssl/ldap.pem
#TLSCertificateKeyFile /etc/openldap/ssl/ldap.pem
#TLSCACertificateFile /etc/ssl/ldap.pem
# Define global ACLs to disable default read access.
# Do not enable referrals until AFTER you have a working directory
# service AND an understanding of referrals.
#referral ldap://root.openldap.org
pidfile /var/run/openldap/slapd.pid
argsfile /var/run/openldap/slapd.args
# Load dynamic backend modules:
# modulepath /usr/lib/openldap/openldap
# moduleload back_bdb.la
# moduleload back_ldap.la
# moduleload back_ldbm.la
# moduleload back_passwd.la
# moduleload back_shell.la
# Sample security restrictions
# Require integrity protection (prevent hijacking)
# Require 112-bit (3DES or better) encryption for updates
# Require 63-bit encryption for simple bind
# security ssf=1 update_ssf=112 simple_bind=64
# Sample access control policy:
i# Root DSE: allow anyone to read it
# Subschema (sub)entry DSE: allow anyone to read it
# Other DSEs:
# Allow self write access
# Allow authenticated users read access
# Allow anonymous users to authenticate
# Directives needed to implement policy:
# access to dn.base="" by * read
# access to dn.base="cn=Subschema" by * read
access to attrs=userPassword
by dn="cn=manager,o=unisis,c=br" write
by self write
by anonymous auth
by * none
# Full rights to the admin
access to *
by * read
# if no access controls are present, the default policy
# allows anyone and everyone to read anything but restricts
# updates to rootdn. (e.g., "access to * by * read")
# rootdn can always read and write EVERYTHING!
# BDB database definitions
database bdb
suffix "dc=unisis,dc=br"
rootdn "cn=Manager,dc=unisis,dc=br"
# Cleartext passwords, especially for the rootdn, should
# be avoid. See slappasswd(8) and slapd.conf(5) for details.
# Use of strong authentication encouraged.
#rootpw secret
rootpw {MD5}vIkT22XHZaojkRfrr2t5Fw==
# The database directory MUST exist prior to running slapd AND
# should only be accessible by the slapd and slap tools.
# Mode 700 recommended.
directory /var/lib/openldap-data
# Indices to maintain
index objectClass eq
e o arquivo ldap.conf esta assim:
# LDAP Defaults
# See ldap.conf(5) for details
# This file should be world readable but not world writable.
BASE dc=unisis, dc=br
URI ldap://zeus.ldap.unisis.br:636/
TLS_REQCERT allow
Ja estou alguns dias tentando configurar o ldap e não saiu do lugar, uso o gentoo no servidor.
se alguem puder me ajudar, agradeço muito...
Falow
