#Porta Proxy
http_port 3128
#hierarchy_stoplist cgi-bin ?
no_cache deny QUERY
cache_mem 64 MB
cache_swap_low 90
cache_swap_high 95
maximum_object_size 30000 KB
minimum_object_size 0 KB
maximum_object_size_in_memory 4000 KB
cache_log /var/log/squid/cache.log
cache_swap_log /var/log/squid/swap.log
dns_nameservers 200.204.0.10/200.204.0.138
#Bloqueio e Liberacao de Sites
acl ipsliberados src "/etc/squid/liberados/ips.txt"
acl arquivosliberados src "/etc/squid/liberados/arquivos.txt"
acl arquivosbloqueados urlpath_regex -i "/etc/squid/bloqueados/arquivos.txt"
acl bloqueados url_regex -i "/etc/squid/bloqueados/block.txt"
acl liberados url_regex -i "/etc/squid/liberados/unblock.txt"
acl rede_interna src 200.200.0.0/16
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl CONNECT method CONNECT
http_access deny !Safe_ports
http_access deny arquivosbloqueados !arquivosliberados
http_access allow ipsliberados
http_access deny bloqueados !liberados
http_access allow rede_interna
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_with_proxy on
http_access deny all
icp_access allow all
visible_hostname servidor
