Postado originalmente por
rootmaster
Pessoal ... estou tentando com o PPTPD, só que a conexão está caindo ...
verificando nos logs ... vi o erro ....
Sep 19 15:03:22 matrix pptpd[8158]: CTRL: Client 192.168.0.98 control connection started
Sep 19 15:03:22 matrix pptpd[8158]: CTRL: Starting call (launching pppd, opening GRE)
Sep 19 15:03:22 matrix pppd[8159]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Sep 19 15:03:22 matrix pppd[8159]: pptpd-logwtmp: $Version$
Sep 19 15:03:23 matrix pppd[8159]: pppd 2.4.3 started by root, uid 0
Sep 19 15:03:23 matrix pppd[8159]: Using interface ppp0
Sep 19 15:03:23 matrix pppd[8159]: Connect: ppp0 <--> /dev/pts/1
Sep 19 15:03:26 matrix pptpd[8158]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Sep 19 15:03:26 matrix pppd[8159]: MPPE required, but kernel has no support.
Sep 19 15:03:26 matrix pppd[8159]: Connection terminated.
Sep 19 15:03:26 matrix pppd[8159]: Connect time 0.1 minutes.
Sep 19 15:03:26 matrix pppd[8159]: Sent 0 bytes, received 44 bytes.
Sep 19 15:03:26 matrix pppd[8159]: tcflush failed: Input/output error
Sep 19 15:03:27 matrix pppd[8159]: Exit.
Sep 19 15:03:27 matrix pptpd[8158]: CTRL: Client 192.168.0.98 control connection finished
já de cara vi que meu Kernel não está abilitado para o MPPE ...
tenho que realmente recompilar meu kernel ... ?
minha distro.:
Linux matrix 2.6.10-1.766_FC3 #1 Wed Feb 9 23:05:07 EST 2005 i586 i586 i386 GNU/Linux
ou tem alguma sujestão .... ??? ??? ???
