#### Arquivo de configuração do Squid 2.5.9 ####
#### Por Junio Vitorino - [email protected] ####
hierarchy_stoplist cgi-bin ?
acl QUERY urlpath_regex cgi-bin \? no_cache deny QUERY
### Cache
cache_mem 128 MB
cache_swap_low 90
cache_swap_high 95
maximum_object_size 30000 KB
minimum_object_size 0 KB
maximum_object_size_in_memory 4000 KB
cache_dir ufs /var/spool/squid 5000 16 256
cache_log /var/log/squid/cache.log
cache_swap_log /var/log/squid/swap.log
debug_options ALL, 2
dns_nameservers 200.20.158.77
client_netmask 255.255.255.0
### Fim de cache
hosts_file /etc/hosts
refresh_pattern . 0 20% 4320
### Acl's Personalizadas
acl admin src 10.0.1.230
acl proibido url_regex -i "/etc/squid/filtros/proibido"
acl liberado url_regex -i "/etc/squid/filtros/liberado"
acl ext_block url_regex -i "/etc/squid/filtros/ext_block"
acl ext_unblock url_regex -i "/etc/squid/filtros/ext_unblock"
### Fim Acl's Personalizadas
### http_access personalizadas
http_access deny proibido !liberado !admin
http_access deny ext_block !ext_unblock !admin
### Fim http_access personalizadas
### Acl's Padrões squid.conf
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563 # https, snews
acl SSL_ports port 873 # rsync
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 631 # cups
acl Safe_ports port 873 # rsync
acl Safe_ports port 1483 # SQLSERVER
acl purge method PURGE
acl CONNECT method CONNECT
### Fim Acl's Padrões squid.conf
### Delay Pools
acl administrativo url_regex -i 10.0.1
acl academico url_regex -i 10.0.0
delay_pools 2
delay_class 1 2
delay_parameters 1 -1/-1 -1/-1
delay_class 2 2
delay_parameters 2 5000/5000 5000/5000
delay_access 1 allow administrativo
delay_access 2 allow academico
### Fim Delay Pools
### Http_Access padrão squid.conf
http_access deny manager
http_access deny purge
http_access deny !Safe_ports
http_access allow localhost
http_access allow all
http_reply_access allow all
### Fim http_access padrão squid.conf
icp_access allow all
miss_access allow all
visible_hostname gateway.facsal.br
coredump_dir /var/spool/squid
### Transparencia
httpd_accel_host virtual
httpd_accel_port 80
httpd_accel_single_host off
httpd_accel_with_proxy on
http_port 3128
### Fim de Transparencia
