Pessoal peço ajuda de vc´s mestres do linux pois estou tentando instalar o spam killer que eu ja instalei em outros micros ai fui instalar no suse 10.1 e quando executa o binario da o seguinte erro abaixo . ele é bem simples em python poderiam me dizer como resolver
## ERRO##
/usr/lib/python2.4/whrandom.py:38: DeprecationWarning: the whrandom module is deprecated; please use the random module
DeprecationWarning)
Attention:
## CODIGO DO EXECUTAVEL ##
import os
import sys
import traceback
try:
## Add the default modules path
sys.path.append("/usr/lib/ask")
sys.path.append("/usr/share/ask")
import askversion
import asklog
import askconfig
import askmail
import askmessage
import askmain
## Create the config and log objects.
## logfile and loglevel are set according to the command line
config = askconfig.AskConfig(sys.argv)
log = asklog.AskLog(config.logfile)
log.loglevel = config.loglevel
## Create the main ASK instance and execute it
ask = askmain.AskMain(config, log)
rc = ask.filter(sys.stdin)
except:
## Try to open the file in $HOME. If it fails, try /tmp
## In any case, send the traceback to the sender so we
## increase the chances people will notice the problem
## and have information to report.
if os.getenv("HOME"):
err_prefix = os.getenv("HOME")
else:
err_prefix = "/tmp"
err_filename = os.path.join(err_prefix, "ASK-FATAL-ERROR.%s" % os.getpid())
fh = open(err_filename, "w")
(type, value, tback) = sys.exc_info()
traceback.print_exc(tback,fh)
fh.close()
## Try to return some information to the sender
sys.stderr.write("Attention:\n\n")
sys.stderr.write("The system could not deliver your message due to a technical problem.\n")
sys.stderr.write("Information about the problem has been recorded locally for analysis.\n\n")
sys.stderr.write("--- Problem Details ---\n\n")
traceback.print_exc(tback)
sys.stderr.write("\n-----------------------\n")
rc = 100 ## 100 forces Qmail (at least) to declare "hard error"
sys.exit(rc)
