- Problemas com apt-get
Srs. Estou com problema no apt-get
quem puder me ajudar serei grato
segue o erro
firewall:/etc# apt-get install slapd
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
slapd: Depends: libperl5.8 (>= 5.8.4) but it is not going to be installed
E: Broken packages
aerofirewall:/etc# apt-get install libperl5.8
libperl5.8: Depends: perl-base (= 5.8.4-8sarge5) but 5.8.8-6.1 is to be installed
E: Broken packages
firewall:/etc#
Cara vc não vai consegui instalar provavelmente pq vc ta usando a versão stable do debian pro apt e ele necessita de pacotes da versão unstable, que vc não tem como instalar já que ta com outra versão, ou vc muda o repositorio e arrisca seu sistema usando pacotes que os desenvolvedores do debian consideram unstable ainda ou vc fica sem o pacote que vc quer instalar.
falows
Você alterou o seu sources.list? Como que ele tá?
Saudações,
Se for o caso de estar usando stable, vc pode procurar essa lib nos backports http://www.backports.org/
abraço.
surces.list
deb Index of /debian stable main
deb-src Index of /debian stable main
deb Debian -- Security Information stable/updates main
uname -a
Linux firewall 2.4.18-bf2.4 #1 Son Apr 14 09:53:28 CEST 2002 i686 GNU/Linux
